Unlock User
Unlock User
Unlock User
This step unlocks the specified Oracle user from the oracle database.
Limitations:
On Oracle 12C database the plugin works for only CDB (Container Database). It does not work for PDB (Pluggable Database).
Step Name
Connection:
Server Name/IP
The Hostname/serve name/IP of the Oracle database.
This field is mandatory.
Port Number
The port number of the Oracle database. Port number should be a positive integer. This field is mandatory.
SID/ Service name
Unique database name or service name.
Username
The username having permission to Delete User (Ex:- sysdba). This field is mandatory.
Password:
Checkbox: Accept Value as variable/static
Leave checkbox unchecked to accept Password value from a field in the previous steps of the stream using a drop down list.
Else enable checkbox for Password field to appear as Text box.
Password
The Password to the username to authenticate to Oracle database. Password is entered using a widget. The widget handles both Text Var(static value or environment variable) and Combo(drop down containing values from previous steps). This field is mandatory.
If checkbox above is enabled Password field appears as Text box. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Button:
8
Test Connection
Verifies whether the connection is established or not.
NOTE: Test Connection button does not work for previous step variables. Test Connection button only works with static values and environment variables.
Input Tab:
Input Fields:
Username to unlock
Username of user account to be unlocked in the database. This field is mandatory.
Output Tab:
Output Fields:
Result
Output field to hold the result of the successful plugin execution.
Refer Appendix 1: Error Handling in IT Plugins
