Active Directory
Active Directory plugin steps are for the purpose of automating Microsoft Windows Active Directory tasks.
Prerequisites:
Below, is a documentation of the AD Plugin step’s.
This step is used to add existing Active Directory Account to an Active Directory Group.
Input Tab: | ||
No. | Field Name | Description |
1 | Step Name | Name of the step. This name has to be unique in a single workflow. |
Configuration: | ||
2 | Server Name | Provide the Hostname/Server Name/Fully Qualified Domain Name/IP address of machine where Active Directory is hosted. This field is mandatory. |
3 | Port | The port number for Active Directory should be provided. If port number is not provided, internally default port for Active Directory is used i.e. 389. Port should be an integer. |
4 | Username | |
Password: | ||
5 | Accept Value as variable/static | Leave checkbox unchecked to accept Password value from a field in the previous steps of the stream using a drop down list. Else enable checkbox for Password field to appear as Text box. |
6 | Password | Password is entered using a widget. The widget handles both Text Var (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text Var and accepts static or variable values. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
7 | Button: Test Connection | Verifies whether the connection is available or not. For the purpose of verification fields coming from previous steps are not allowed since field values can only be accessed when workflow is in running state. Static values and environment variables are allowed. |
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Object Type allowed values are only “ ’User’, ‘Computer’, ’Group’” Note: Double quotes (") and back quote (`) are not to be provided. |
2 | Object Name | Provide Object name of an existing account in Active Directory to Add to Group, corresponding to the Object Type chosen above.
The data type is string. This field is mandatory. Object Name must be unique in Active Directory. Note: Object Name(CN) in Active Directory should not contain a slash(/ or \) |
3 | Group Name | Existing Active Directory Group Name in formats such as Group Name (CN) or Canonical name or Distinguished name to which we intend to add an existing Active Directory object. Note: Group Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user has been added to AD group. This field is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Search Account plugin step provides the list of all Active Directory Users or Groups for the specified Object Type for the Path specified and with Property search criteria provided.
Input Tab: | ||
Configuration: | ||
4 | Username | |
6 | Password | Specify the password for the username above. Password field appears as Text box and accepts static values or variables. The data type is string. The field is mandatory. |
7 | Button: Test Connection | Verifies whether the connection is available or not. For the purpose of verification fields coming from previous steps are not allowed. Static values and environment variables are allowed. |
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Hover over the field to see Allowed values are ‘User’, ‘Group’. The data type is String. This field is mandatory. |
2 | Path | Provide the path of an Active Directory object for Advanced Search usually Distinguished name (DN) (e.g. OU=Temp, DC=autoedge, DC=com) or Canonical name (e.g. automationedge.com/Temp) of the object. The data type is String. This field is mandatory. |
Tabular Fields: | Atleast one Property Name, Search Condition and respective Property Value must be selected in the table fields. | |
3 | Property Name | Double click to select Property Names form the pop up window. The data type is String. This field is mandatory. This field is mandatory. |
4 | Search Condition | Select a Search Condition from the dropdown list. Following are the values in the list. The data type is String. This field is mandatory.
5 | Property Value | Provide a desired property value. The data type is String. This field is mandatory. |
Output Tab: | ||
Output Field: | ||
1 | Name | Specify an output field to hold the result- Name upon successful plugin execution. The default label value for this field is “Name”. This field is mandatory. |
2 | Distinguished Name | Specify an output field to hold the result-Distinguished Name on the successful plugin execution. The default label value for this field is “DistinguishedName”. This field is mandatory. Note: Advance Search returns Name and Distinguished Name as output. In case you need to use the output of Advanced Search but additionally need User Logon Name then you need to use Get User Properties step after Advanced Search in the workflow to get the User Principal Name by providing DN as input. (e.g. Suppose you want to know Does User Exist/ Is Account Locked for all the users returned in Advanced Search, you need User Principal Name to input DoesUserExist/IsAccountLocked steps. Get User Properties step after Principal Name can fetch the User Principal Name). |
Active Directory: Create Account Plugin step is used to create a new Active Directory user.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
5 | Accept Values from fields | Leave checkbox unchecked to accept Password value from a field in the previous steps of the stream using a drop down list. Else enable checkbox for Password field to appear as Text box. |
6 | Password | Password is entered using a widget called SecuredComboVar. The widget handles both Text Var(static value or environment variable) and Combo(drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text Var and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | First name | First name of the user account to be created. This field is mandatory. |
2 | Last name | Last name of the user account to be created. This field is mandatory. |
3 | Full name | Full name of the user account to be created. This field is mandatory. |
4 | User logon name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) for the new account to be created. User Logon Name is mandatory. |
5 | User logon password | Provide a password for the user Account to be created. |
6 | Path | Provide path of Active Directory object (usually DN, For e.g. OU=Temp, DC=autoedge,DC=com) where the User Account is to be created. This field is mandatory. |
The account is created if the password fails for any reason. If you provide a password, an attempt will be made to set that password however, this can fail due to password policy restrictions. The user account will still be created and you may use Reset Account Password to set the password on that account. In order to ensure that accounts remain secure, user accounts will never be enabled unless a valid password is set or Password Not Required is set in AD.
Output Tab: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user account has been created. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Create Group Plugin step is used to create a new Active Directory Group.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
5 | Password | Password is entered using a widget called SecuredComboVar. The widget handles both Text Var (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text Var and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
6 | Button: Test Connection | Verifies whether the connection is available or not. For the purpose of verification fields coming from previous steps are not allowed as field values can only be accessed when workflow is in running state. Static values and environment variables are allowed. |
Input Tab: | ||
Input Fields: | ||
1 | Group name | Provide an AD Group Name. The Group name must be unique in the active directory domain. This field is mandatory. |
2 | Group Scope | Allowed values for Group scope are “ ‘0’, ’1’, ’2’ or ‘Domain local’, ’Global’, ’Universal’ ”. This field is mandatory. |
3 | Group Display Name | Provide a display name of the Group. This field is mandatory. |
4 | Group Category | Group category allowed values are only “ ‘0’,’1’ or ’Distribution’, ‘Security’”. This field is mandatory. |
6 | Path | Provide the path of Active Directory object where the Group is to be created - usually Distinguished Name (DN) (e.g. OU=Temp, DC=autoedge, DC=com) or Canonical Name (e.g. automationedge.com/Temp). This field is mandatory. |
Output Tab: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user group has been created. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Delete Account step is deletes an Active Directory User Account.
Input Tab: | ||
Configuration: | ||
4 | Username | |
Password: | ||
6 | Password | Password is entered using a widget. The widget handles both Text Var (static value or environment variable) and Combo(drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text Var and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | User Logon Name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) that is to be deleted. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted. The data type is String. User Logon Name is mandatory. Note: User Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user account has been deleted. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Delete Group plugin step deletes an existing Active Directory Group.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
6 | Password | Password is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | Group Name | Specify the Group Name (CN)/Distinguished Name/Canonical Name in active directory to be deleted. This field is mandatory. Canonical name\Distinguished Name may be provided in the group name field to avoid duplicate group name errors. Group Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
1 | Result | Output field to hold the result of the successful plugin execution. The default value of this field is “Result”. This field is mandatory. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Disable Account Plugin step disables a user or computer account.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
6 | Password | Password is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as a Text box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Object Type allowed values are only “ ’User’, ‘Computer’” Note: Double quotes (") and back quote (`) are not to be provided. |
2 | Object Name | Provide an existing Active Directory object name (user or computer name) which we intend to disable.
The data type is string. This field is mandatory. Object Name must be unique in Active Directory. Note: User Name(CN) in Active Directory should not contain a slash(/ or \) |
This plugin checks the current status of an existing Active Directory Group.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Group name | Provide Active Directory Group name (CN i.e. Common Name) or Canonical name or Distinguished name to check if it exists. This field is mandatory. Note: Group Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows whether group exists or does not exist. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
The step is used to check the status of an Active Directory user if it exists or does not exist.
Input Tab: | ||
Configuration: | ||
4 | Username | |
Password: | ||
6 | Password | Password is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text Var and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | User Logon Name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) to check if user exists. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted. The data type is String. User Logon Name is mandatory. Note: User Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user exists. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Enable Account step is used to enable a disabled user or computer account.
Configuration: | ||
No. | Field Nameve | Description |
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Object Type allowed values are only ‘User’, ‘Computer’. The data type is String. This field is mandatory. Note: Double quotes (") or back quote (`) are not to be provided. |
2 | Object Name | Specify the name of an existing Active Directory object to be enabled, corresponding to the Object Type chosen above.
Active Directory: Get Computers plugin step provides the list of all active directory computers on a specified path for the hierarchical scope specified.
This is a row generating step and hence has to be the first step in a workflow.
Configuration: | ||
Configuration: | ||
4 | Username | |
Input Tab: | ||
Input Fields: | ||
1 | Path | Provide path of Active Directory usually Distinguished Name (DN) (e.g. OU=Temp, DC=autoedge, DC=com or) or Canonical Name (e.g. e.g. automationedge.com/Temp) for which we want to get all the Computers. The Data type is String. This field is mandatory. |
2 | Search Scope |
Output Tab: | ||
1 | Computers | Specify an output field to hold the Computer Name on the successful plugin execution. The default value for this field is “Computers”. |
2 | Distinguished Name | Specify an output field to hold the Distinguished Name of a computer on the successful plugin execution. The default value for this field is “DistinguishedName”. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get Groups plugin step provides the list of all active directory groups on a specified path.
Configuration: | ||
Configuration: | ||
4 | Username | |
5 | Password | Specify the password for the username above. Password field appears as Text box and accepts static values or variables. The data type is string. The field is mandatory. |
6 | Button: Test Connection | Verifies whether the connection is available or not. For the purpose of verification fields coming from previous steps are not allowed. Static values and environment variables are allowed. |
Input Tab: | ||
Input Fields: | ||
1 | Path | Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Groups.
Path data type is String. Path is mandatory. Note: Double quotes (") and back quote (`) are not required as part of input. |
2 | Search Scope |
Output Tab: | ||
1 | Groups | Specify an output field to hold the result of the successful plugin execution. Default label value for this field is “Groups”. Result label value is mandatory. |
2 | Distinguished Name | Specify a field name to store the Distinguished Names of the Groups retrieved. The default value is “Distinguished Name”. Result label value is mandatory. Errors can be captured using error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get Group Properties plugin step gets the properties of an Active Directory Group.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Group Name | Specify an Active Directory Group Name (CN)\Canonical Name\ Distinguished Name to get the Group properties. Canonical name\Distinguished Name may be provided to the group name field to avoid duplicate group name errors. Note: Group Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Fields Tabular: | ||
1 | Property Name | Double click to get a list of Group property names. At least one property name should be selected. |
2 | Output Field | Specify a field name to store the retrieved property values of the corresponding property names. |
Active Directory: Get Organizational Units plugin step provides the list of all active organizational units for a specified path.
Configuration: | ||
Configuration: | ||
4 | Username | |
Input Tab: | ||
Input Fields: | ||
Path | Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Organizational Units.
Path data type is String. Path is mandatory. Note: Double quotes (") and back quote (`) are not required as part of input. | |
Search Scope |
Output Tab: | ||
1 | OU Name | Specify a field name to store the OU names retrieved. The default value is “OU Name” |
2 | Distinguished Name | Specify a field name to store the Distinguished Names of the OU names retrieved. The default value is “Distinguished Name” Errors can be captured using error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get Last Logon Timestamp plugin step gets the last logon timestamp of an Active Directory user or computer.
Configuration: | ||
Configuration: | ||
2 | Server Name | Provide the Hostname/Server Name/Fully Qualified Domain Name/IP address of the machine where Active Directory is hosted. This field is mandatory. |
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Specify Object Type - allowed values are only “’User’ and ‘Computer’”. The data type is String. This field is mandatory. Note: Double quotes (") and back quote (`) are not to be provided. |
2 | Object Name | Specify an existing Active Directory object name for which we wish to get the last logged in timestamp.
Output Tab: | ||
1 | Last LogonTimestamp (UTC) | Output field to hold the result of the successful plugin execution. Default value for this field is “LastLogonTimestamp”. This field is mandatory. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get Users step provides the list of all Active Directory users on the Path specified. This is a row generating step and hence has to be the first step in a workflow.
Configuration: | ||
Configuration: | ||
4 | Username | |
Input Tab: | ||
Input Fields: | ||
1 | Path | Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Users. Advanced Features must be enabled from View menu to fetch Canonical name or Distinguished Name from the Object Properties.
2 | Search Scope |
Output Tab: | ||
1 | Users | Specify an output field to hold the result (User Logon Name/User Principal Name) upon successful plugin execution. The default value for this field is “Users”. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get User Groups step provides the list of all groups for a specified user. This is a row generating step and hence has to be the first step in a workflow.
Configuration: | ||
Configuration: | ||
4 | Username | |
Input Tab: | ||
Input Fields: | ||
1 | User Logon Name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) for which you need all the assigned groups. You may also provide the User Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to fetch assigned groups. User Logon Name is mandatory. |
Output Tab: | ||
1 | User Groups | Output field to hold the result of the successful plugin execution. Default label value for this field is “User Groups”. Result label value is mandatory. |
2 | Distinguished Name | Specify an output field to hold the result-Distinguished Name on the successful plugin execution. The default label value for this field is “DistinguishedName”. This field is mandatory. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Get User Properties step gets the properties of an Active Directory user.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | User Logon Name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal name (e.g. sbrown@autoedge.com) of the user for which you wish to fetch User Properties. You may also provide the User Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to fetch User Properties. The data type is String. User Logon Name is mandatory. Note: User Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Tabular Fields: | At least one Property Name and Respective Output field should be provided. | |
1 | Property Name | On Click, property names associated with the user are retrieved in a list. Select one or more Property Names one by one. |
2 | Output Field | Specify an output fieldname to hold the value of the corresponding Property Name. |
Active Directory: Is Account Disabled plugin step checks whether the current status of an existing Active Directory account is disabled.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
6 | Password | Password is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory. If checkbox above is enabled Password field appears as Text b box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps. |
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Object Type: Allowed values are ‘User’, ‘Computer’. The data Type is String. This field is mandatory. |
2 | Object Name | Specify an existing Active Directory object name for which you wish check if Acount is disabled.
Output Tab: | ||
1 | Result | Specify an output field to hold the result of the plugin execution. Default label value for this field is “Result”. Result label value is mandatory. If Account is disabled the Result is true else false. |
Active Directory: Is Account Locked plugin checks whether the current status of an existing Active Directory account is locked.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Specify an Object Type. The allowed values are ‘User’, ‘Computer’. The data type is string. This field is mandatory. |
2 | Object Name | Specify an existing Active Directory object name for which you wish check if Acount is locked.
Output Tab: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Result label value is mandatory. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Move Account Plugin step is moves a user from one organization (OU) to another organization in Active Directory.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Specify the Object Type. Allowed values are ‘User’, ‘Computer’, ‘Group’. The data type is string. This field is mandatory. |
2 | Object Name | Specify the name of an existing Active Directory object which you wish to move.
3 | Destination Path | Give the object path (usually OU DN) to which you want to move the active directory account This field is mandatory. Specify the Object Destination Path as Distinguished Name Path (usually OU DN - e.g. OU=Temp, DC=autoedge, DC=com) or Canonical Name Path where the user is to be moved (e.g. automationedge.com/Temp). |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user account has been moved. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Active Directory: Password Expiration Days Left plugin step searches a given Object (User or Computer) and gets password expiration days left.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Specify Object Type - allowed values are “’User’ and ‘Computer’”. The data type is String. This field is mandatory. Note: Double quotes (") or back quote (`) are not to be provided. |
2 | Object Name | Specify an existing Active Directory object name for which you get the Password Expiration Days left.
Output Tab: | ||
1 | Password Expiration Days Left | Output field to hold the result of the successful plugin execution. Default label value for this field is “PasswordExpirationDaysLeft”. Result label value is mandatory. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
This plugin is used to remove an existing Active Directory account from an existing Active Directory group.
Input Tab: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
2 | Object Name | Provide Object name of an existing account in Active Directory; that you wish to Remove from Group; corresponding to the Object Type chosen above.
3 | Group Name | Existing Active Directory Group Name in formats such as Group Name (CN) or Canonical name or Distinguished name from which we intend to remove an existing Active Directory object. This field is mandatory. Note: Group Name(CN) in Active Directory should not contain a slash(/ or \) |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows Account has been removed from Group. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. Result label value is mandatory. |
Active Directory: Rename Account plugin step is renames an Active Directory Account.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | Object Type | Object Type allowed values are only “’User’, ‘Computer’, ‘Group’”. The data type is String. This field is mandatory. Note: Double quotes (") and back quote (`) are not to be provided. |
2 | Object Name | Specify an existing Active Directory object name to be renamed.
3 | New Name | Specify a new Name (CN) for the object to be renamed. This field is a String. The field is mandatory. |
The step is used to reset password of an existing AD user.
Input Tab: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | User logon name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) to reset password. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted. The data type is String. User Logon Name is mandatory. Note: User Name(CN) in Active Directory should not contain a slash(/ or \) |
2 | New Password | New password which we intend to set for the above User logon name. This field is mandatory. |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user password has been reset. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. Result label value is mandatory. |
Active Directory: Set Password Properties plugin step sets password properties for an existing user account in Active Directory.
Configuration: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | User Logon Name | Specify an existing Active Directory User to set password properties.
User Must Change Password At Next Logon | Give the appropriate property value. Allowed values are ‘0’, ’1’ or ‘true’, ‘false’. The data type is String. This field is mandatory. | |
3 | User Cannot Change Password | Give the appropriate property value. Allowed values are ‘0’, ’1’ or ‘true’, ‘false’. The data type is String. This field is mandatory. |
4 | Password Never Expires | Give the appropriate property value. Allowed values are ‘0’, ’1’ or ‘true’, ‘false’. The data type is String. This field is mandatory. |
The step is used to unlock AD user account which is locked (i.e. user account gets locked when we enter wrong credentials multiple times).
Input Tab: | ||
Configuration: | ||
4 | Username | |
Password: | ||
Input Tab: | ||
Input Fields: | ||
1 | User logon name | Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) of an existing Active Directory account to unlock account. You may also specify Distinguished Name or Canonical of the User Account. The data type is string. User Logon Name is mandatory. |
Output Tab: | ||
Output Field: | ||
1 | Result | Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Successful execution shows user account has been unlocked. Result label value is mandatory. Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in 27 Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests. |
Known Issues:
These known errors are for all AD plugins
Reference Link: https://bugs.java.com/view_bug.do?bug_id=7028657
