Issue
Error on server : Workflow is using plugins which are incompatible with the server.
How to Reproduce:
To reproduce this issue, you can try
> Downgrading one of the plugin version on the server (Say WebGui jar 1.9)
> Create a workflow with the same plugin (Say WebGui jar 1.9)
> Upgrade the Plugin on the server(Say WebGui jar 1.10) and upload the workflow which you have created in version (WebGui jar 1.9).
Solution
- Before Exporting, Kindly sync the Plugins with the server.
- In this situation the Plugins in the Process studio should be same as Server there should be no mismatch.
- If a new plugin is added in Process Studio, you should upload the same on the server
