Workflow configuration : How to Terminate long running job
How to Terminate long-running job
Resolution:-
In the workflow configuration, you need to specify expected time and maximum time to complete a workflow from the time it is triggered.
Once the max execution time is crossed then the terminate button will be visible on the portal and we can terminate that request manually. There is no such option which can terminate the process automatically.
Refer below screenshot-
Also, refer to the section 8.1.3 Manual Termination of Requests/Workflow in AutomationEdge user guide to terminate the process manually.
