'wmic' is not recognized as an internal or external command,operable program or batch file. not found in PROGRAMFILES directory
2021-10-27 17:07:52 Workflow_1 - Start Browser ERROR BrowserUtil:362 - 'wmic' is not recognized as an internal or external command,operable program or batch file. not found in PROGRAMFILES(X86) directory
2021-10-27 17:07:52 Workflow_1 - Start Browser ERROR BrowserUtil:362 - 'wmic' is not recognized as an internal or external command,operable program or batch file. not found in PROGRAMFILES directory
2021-10-27 17:07:52 Workflow_1 - Start Browser ERROR ProcessStudioException:54 - Unable to find Google Chrome on the system
2021-10-27 17:07:52 Workflow_1 - Start Browser ERROR BrowserUtil:424 - com.automationedge.ps.core.exception.ProcessStudioException:
 not found in {1} directory
1) Go to MyComputer properties
2) Click on the ‘advanced System setting’ tab
3) Click on ‘Environment variables’
4) Select the "PATH" variable and click on the edit button under ‘System Variable’
5) Add below path under "PATH" variable and restart process-studio/agent
 ;C:\Windows\System32\wbem;
