What kind of validation is done by Mail Validator Step
Problem Statement:
What kind of validation is done by Mail Validator Step?
- The mail Validator step checks if an email address is valid or not. The Mail Validator step returns a result field (Boolean or String depending on your settings).
- By default, Process studio will only check email address structure (using a regular expression).
- If you want to perform an SMTP checking then select ‘SMTP check? ‘Option and fill ‘Email sender’ details. Process studio will extract the domain name from the supplied email address (to check) and will try to get all exchangers from the domain name. Each exchanger will be queried.
- If you know which SMTP server to query, please specify ‘Default SMTP server’, Process studio will then query only the specified SMTP server.
