AutomationEdge Web Automation Guide
Web Automation Guide [Web GUI]
Plugin Reference Guide
Web GUI
WebGUI plugins are used for automation of web applications.
Any type of UI Automation with Web GUI plugin steps is supported on Windows and Linux based OS. The following browser versions are supported for WebGUI Automation/Web Spy in Release 2.1.
Browser Support
OS
Chrome
Firefox
IE
 Release 2.1
Windows
75 to 88
38 to 47
8 to11
Linux
80 to 88
Prerequisites:
  1. . Upload the latest browser drivers for WebGUI plugin as follows,
  1. Upload the latest browser drivers (e.g. <CHROME<VERSION>.zip>) for WebGUI Plugin - using Plugin Management on AutomationEdge UI. (Refer section - File Management in AutomationEdge_System_Administrator_Guide_R6.0.0).
  2. Once uploaded the driver is available for both Process Studio and Agent. For Process Studio, additionally, perform Plugin Sync operation so that the drivers are available for automation.
Web Spy may be used to build workflows with WebGUI plugin steps. For a description on how to use Web Spy refer the following: Appendix 7: Web Spy Tutorial. The Web Spy tutorial also has a Sample Workflow with Web Spy
Close Web Window
The Close Web Window step closes the current browser window in Web GUI automation.
Web Browser Name
You can select any one Web Browser Name from the given list,
Basically you must select the same Web Browser Name which was selected in Start Browser Step.
Common Buttons
Help
Click to see the Plugin description and configuration details.
OK
Click OK button to accept configurations.
Cancel
Click CANCEL button to discard configurations.
Exit Browser
The Exit Browser step explicitly closes the entire browser session for the driver specified in Web GUI automation.
Note: When a WebGUI workflow is run on an agent the entire browser session implicitly closes after the end of the workflow even if Exit browser is not put at the end of the workflow.
However, when a WebGUI workflow is run from Process Studio, the entire browser session does not close implicitly.
Browser terminates abnormally and then you need to clear browser driver instance before you can start a new browser. Navigate to Tools and Clear All Browser Instances as shown below.
Web Browser Name
Common Buttons
Help
OK
Cancel
Get Current Window Title
The Get Current Window Title Web GUI plugin step gets the title of the current browser window.
Step Name
Web Browser Name
You can select any one Web Browser Name from the given list (BROWSER1, BROWSER1). You must select the same Web Browser Name which was selected in Start Browser Step.
Window title field
Specify a fieldname to hold the retrieved Window Title. The default value is windowTitle.
Common Buttons
Help
OK
Cancel
Inject Java Script
Inject java Script is used to inject java script in a Web GUI automation workflow. Sometimes web control with web locators doesn’t react well as it is unable to perform the action. At such times this step can be very useful to perform web actions.
Inject Java Script automatically gets the web handle for the Web Browser chosen in Web Browser Name selection which is not available automatically in other scripting steps.
No
Web Browser Name
Inject Java Script automatically gets web handle from the selection.
Left Pane:
Get Input Fields
By clicking on this it will give a list of all input fields that can be used as a part of Inject Java Script.
Code Snippets:
Sample Code
Double click Sample Code to populate sample code in the Inject Java Script right hand pane. Here you will find an example to make fields available to next step.
Partial pseudo code for making multiple fields available to next step,
  var FieldName = "FieldName";
  var FieldValue = "FieldValue";
  var FieldName2 = "FieldName2";
  var FieldValue2 = "FieldValue2";
  return "<<>>"+FieldName+"::"+FieldValue+"<<>>;<<>>"+FieldName2+"::"+FieldValue2+"<<>>";
Right Pane:
Inject Java Script
Write the Java Script in the space provided.
Following, is a sample Java Script showing how to set value and click a button.
In this case the code sets values of username and password and clicks a login button.
var chkPrint = document.getElementsByName('uid')[0].value = "mngr169997";
document.getElementsByName('password')[0].value = "YvynEtA";
document.getElementsByName('btnLogin')[0].click();
Common Buttons
Help
OK
Cancel
Start Browser
The Start Browser step initiates the web browser and navigates to the URL specified in Web GUI automation.
Web Browser Name
You can select any one Web Browser Name from the given list.
Browser
Web browser to initialize. Choose from a drop down list containing,
  1. Mozilla
  2. Chrome
  3. Internet Explorer -with Ignore IE Protected mode checkbox (Refer Note 3 below)
Web URL
URL to navigate after web browser is initialized.
Default download directory
Any browser has a default directory path where all files are downloaded.  This feature allows users to overwrite the default download directory. Once a new Default download directory is specified, any file downloaded will be stored in the specified directory.
This setting is only affective for the current browser instance. This option is not available for Internet Explorer.
Maximize Browser
Checkbox to specify if browser window is to be maximized. By default, the browser is not maximized.
Start Node
Checkbox to specify if this step is a start node (no other input steps are connected to this step)
Clear all browser instances
Clear All Browser Instances option is available in Start Browser in addition to the process studio -> tools menu.
When a WebGUI workflow is run from Process Studio the entire browser session does not close implicitly,
  1. Leaving the browser open even when there is an error during development and browser is manually or abnormally terminated.
  2. In case you manually terminate a browser the browser driver is still initialized and when you run the workflow the start step will give an error as the browser is already initialized.
  3. Similarly in case Browser terminates abnormally then you need to clear browser driver instance before you can start a new browser session.
Enable Clear All Browser Instances checkbox to Clear All Browser Instances before starting the browser.
8
Delay (in milliseconds)
Maximum global delay set for the entire session.
9
Notify on browser version change
Enable this checkbox to notify Workflow Administrator and Tenant Administrator if valid emails and SMTP is configured.
10
Page load timeout(in  milliseconds)
The page load timeout in milliseconds for any web page across the workflow. Else the workflow errors out. The page load timeout can be overwritten by the Web URL Navigation step.
11
The total delay in milliseconds for the entire workflow to execute. Delay to locate and perform any action on any web element step, else the workflow errors out
12
Retry count
User can set retry count number and that will be globally used in all steps of WEBGUI for retrying on error. Whenever the execution of WEBGUI step ends up with an error it will retry execution number of time specified in start browser.
If one doesn’t want to retry for some specific steps, retry count can be set to 0 by using ‘Set Retry Count’ Step.  Use of ‘Web Set Retry Count’ is to modify the count specified in Start Browser. Steps after Web Set Retry Count will get newly set Retry Count.
Following steps are excluded from the functionality of Retry Count:
  1. Begin
  2. End
  3. CloseWindow
  4. Robot Handling
  5. SetDelay
  6. SetRetryCount
  7. URL navigation
Notes:
  1. In case of multiple Initialize Web Driver steps in single process/workflow, make sure different drivers are selected.
  2. If delay is specified as 0, default considered is 30 seconds.
  3. In case of IE, starting version 7, notion of 4 Security zones; namely Intranet, Internet, Trusted Sites and Restricted Sites was introduced. The following two scenarios are to be noted in Web GUI automation using IE.
  1. The default behavior in Web GUI automation using IE is to check “Enable Protected Mode” settings for all the zones and throw an error when this setting is different for any two zones.
  2. In Web GUI automation with IE When “Enable Protected Mode” settings are different for different security zones and you navigate from one URL in one zone to another URL in different zone having a different setting for “Enable Protected Mode”, IE internally launches a new process and from that point on, automation fails as it loses the process handle.
In case of Web GUI automation ‘Ignore IE Protected Mode Settings’ checkbox has been introduced inWeb-GUI “Start Browser” step and Web-Spy to handle the two scenarios above.
  1. When “Ignore Protected Mode Settings” is CHECKED in Web-GUI “Start Browser” step and Web-Spy.  “Enable Protected Mode” setting check for different zones is ignored and it starts without error no matter what “Enable Protected Mode” settings for different zones are.
  2. We already have the feature to start WebGUI automation with an initial Browser URL. If during entire automation, browser doesn’t navigate to some other URL but URL specified as initial Browser URL, zone switching never happens and automation works fine.
Common Buttons
Help
OK
Cancel
Web Actions
The Web Actions step gives the option to perform several actions on a specific element on the web page in Web GUI automation. When ‘drag and drop’ action is selected the configurations for destination element is enabled.
Web Browser Name
Action*
Click action to be performed on the web page element.
Source Element:
Criteria*
Locate element on web page
Criteria Value
Relevant criteria value has to be specified.
Multiple elements with same criteria
Check this option if there are multiple web elements in the web page having same criteria value you have specified. By default it will be unchecked.
Element index
If you have checked Multiple elements with same criteria specify index of the element you want to locate.
Select option FIRST if you want first element from the located element and select LAST if you want last element.
Use Coordinates
Enable checkbox to use coordinate options. This option is disabled for drag and drop Action.
X-Coordinate Value
Specify the value of X-Coordinate to move the cursor to specified x-coordinate of the located element.
Y-Coordinate Value
Specify the value of Y-Coordinate to move the cursor to specified y-coordinate of the located element.
8
Destination Element:
When ‘drag and drop’ action is selected the configurations for destination element is enabled. The configurations available are same as 1-4 of source element as above.
*Action
The table below contains the description of each Action.
Click
Perform single click on the web element.
Right Click
Perform right click on the web element.
Double Click
Perform double click on the web element.
Drag and Drop
Will perform drag and drop operation.
Move to element
Will move focus to the specified web element.
Click and Hold
Clicks (without releasing) in the middle of the element.
*Criteria
The table below contains the description of criteria.
No
Xpath
Xpath defines the hierarchy of the tags through which you can reach to a particular element. For example /html/body/div[1]/div/div[3]/div[2]/div/div[2]/div/div/div[2]/div[2]/div[1]/div[1]/div[1]/span/span
Id
Id attribute of a web element can be best way to identify an element if it is present and is going to constant and unique. There are cases however when it is either absent or its value changes every time you access the application in the browser
Name
Name is another attribute of a web element which can be used to identify an element.
Link Text
If a HTML page contains a hyperlink element <a href=www.google.com>Search On Google</a>, you can identify this href element by providing complete text ‘Search On Google’ as the Link value.
Partial Link text
This criteria is same as Link, just that, in this case, you can give partial string for finding a match
Tag Name
Every HTML element has a tag associated with it. The element can be located using that tag name. For example, textbox has a tag <input>.
Class Name
Class name is the css class associated with an HTML element. If there is a div element
<div class=’someclass’>MyDiv</div>, you can locate it by giving class name ‘someclass’.
8
Css Selector
This criteria is useful when an HTML element has multiple associated css classes. Consider an HTML element <div class="btn primary-btn submit"></div>. To identify this div element you can use Css selector as “.btn.primary-btn.submit”
Common Buttons
Help
OK
Cancel
Web Alert
The Web Alert step gives the functionality of handling java script generated alerts in Web GUI automation.
No
Web Browser Name
Alert Operations*
Specify the alert operation to perform
Value
By default this field will be disabled and will be enabled if SetValue alert operation is chosen. Through this field you can specify the value you want to set in the alert.
Output field name
By default this field will be disabled this will be enabled only when you select GetValue alert operation. This allows you to define field name in which alert’s text will be stored.
*Alert Operations
The table below contains the description of each Alert Operation.
No
Accept
Select this option when you want to click “OK/Yes” button of the alert.
Dismiss
This option will dismiss the alert which is appeared on the web page.
SetValue
If any alert is asking you to enter some value in it you can select this option and specify the value in Value field which is entered in the alert.
GetValue
If you want to retrieve alert text choose this option and it will store the retrieved value in the field you have specified in the Output field name.
Common Buttons
Help
OK
Cancel
Web Click
The Web Click step is used to click web element like button, hyper link, image and div. It is basically a single click on the specified web element.
No
Field
Web Browser Name
Criteria*
Criteria Value
Element index
Number of clicks
Put the number of times web click occurs. It should be greater than zero. Default is 1.
*Criteria
No
Field
Xpath
Id
Name
Link Text
Partial Link text
This criteria is same as Link, just that, in this case, you can give partial string for finding a match.
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Composite
The Web Composite step is a singular step that can be used to perform several Web GUI actions.
Note: The step will perform only the basic actions. For the advanced requirements the original steps need to be used.
No
Field
Web Browser Name
Actions Tab Table:
Actions
Choose the Action to be performed from the drop down list.
The following, actions can be performed using the Web Composite step.
  1. Get Value
  2. Set Value
  3. Click
  4. Right Click
  5. Double Click
  6. Click and Hold
  7. Move to Element
  8. Alert SetValue
  9. Alert Getvalue
  10. Alert Accept
  11. Alert Dismiss
  12. Element Displayed
  13. Element Enabled
  14. Element Selected
  15. Page Scroll
  16. Wait Until Alert Present
  17. Wait Until Element Visible
  18. Wait Until Element Present
The following steps are not supported in
  1. Start Browser
  2. Exit Brower
  3. Close Web Window
  4. Robot Handling
  5. Web Drop Down Selection
  6. Web File Upload
  7. Web Loop Table
  8. Web URL Navigation
  9. Web Set Delay
  10. Web Actions  Drag and Drop
Criteria*
Choose the element locator to locate element on web page.
Criteria Value
Specify the relevant criteria value of the element locator to search with.
If there are multiple elements on the same page/frame with same criteria select Yes.
Element index(Starts with 0)
Element index(Starts with 0) is enabled if Multiple elements with same criteria is marked as Yes. Need to specify the index of element to access.Select option FIRST if you want first element from the located element and select LAST if you want last element.
Value
Provide an optional value depending on the action chosen. (Such as if Web Click is chosen as action put the number of times web click occurs. It should be greater than zero. Default is 1; Provide value for Web Set Value).
8
Output field name
Specify an optional new output fieldname to hold value given out by the action depending on the action chosen, example Web Get Value.
9
Delay(in milliseconds)
Specify delay for the particular action. If empty, it is defaulted to the value set by Start Browser or latest Web Set Delay step. This is an implicit delay.
10
Provide an optional description depending on the action chosen.
*Criteria
No
Field
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
Common Buttons
Help
OK
Cancel
Web Download Image
No
Field
Web Browser Name
Criteria
Criteria value
Check this option if there are multiple web elements in the web   having same criteria value you have specified. By default it will be unchecked.
Download Directory
The directory where the image file will be downloaded. The default directory is ${Internal.Entry.Current.Directory} i.e. that is the same location where the workflow is saved.
8
Output file path
Specify a field to hold the Output file path including the file path along with name of the image file downloaded.
No
Common Buttons
Help
OK
Cancel
Web Dropdown Selection
The Web Dropdown Selection step is used to select value of dropdown list on the web page for Web GUI automation.
No
Web Browser Name
Criteria*
Criteria Value
Element index
Select by*
Method to select the dropdown value
Selection value
Relevant value need to be specified for the method selected in Select by
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
*Select by
The table below contains the description of each Select by methods.
No
Index
Suppose located dropdown has 3 options “A,B,C”, now if you want to select “A” give the index value as “0” and so on.
Value
Every item in html dropdown has a value attribute associated with it. If the Value attribute of desired option is known select this option.
Visible Text
Visible Text is the value of the option which user can see on the web page.
No
Common Buttons
Help
OK
Cancel
Web Element Condition
The Web Element Condition step checks specified condition of web page element and returns a Boolean value in Web GUI automation.
No
Web Browser Name
Condition*
Condition to check on web page element.
Criteria*
Criteria Value
Output field name
Name of the output field, which contains the evaluated Boolean value.
*Condition
The table below contains the description of each Condition.
No
Is displayed
Check if web page element is displayed.
Is enabled
Check if web page element is enabled.
Is selected
Check if web page element is selected.
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web File Upload
The Web File Upload step is used for uploading a file with absolute path (browse dialog) on a web page in Web GUI automation.
No
Web Browser Name
File path
Absolute file path for upload
No
Common Buttons
Help
OK
Cancel
Web Get Value
The Web Get Value step allows you to retrieve text of any web element (including dropdown). The retrieved value will be stored in a field value. The step also allows multiple criteria to retrieve text of multiple web elements in Web GUI automation.
No
Web Browser Name
Criteria*
Locate element on web page (including radio button and checkbox)
Criteria value
Element is dropdown
Select Yes/No based on element is dropdown or not.
Select Yes if there are multiple web elements in the web page having same criteria value you have specified, else select No
Element index
If you have selected Yes for Multiple elements with same criteria, specify index of the element you want to locate.
Output field name
Here you can define process studio output field in which retrieved value will be stored.
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Loop Table
The step is used to traverse through an HTML table in Web GUI automation. Either entire table or specific columns can be the output.
The Web Loop Table step is designed to be used within a loop. On drag n drop of this new step, Continue step is also added on the canvas and the validations are same as the Start Loop-Continue Loop steps.
Each row of the table is processed for a single iteration (The rows to be processed are specified in the Loop Tab as All or specific rows or based on a condition). Processing of all the rows specified for a single iteration completes a loop.
The input row and additional fields are passed in the false path after all the rows (as specified in the Loop Tab) are processed.
Validations:
1. If the workflow is using switch case for path decisions inside loop or error handling, all of them must end with Loop Continue Step.
2. Both the steps must be present and connected properly in the workflow.
3. Infinite loop will not be verified.
4. Cannot have Blocking Steps in the loop
5. Steps like Merge Join, Join Rows which wait for all rows before execution start will not be allowed in the loop.
6. Row generating steps like Microsoft Excel Input are not allowed in a loop.
No
Web Browser Name
Web Table Tab:
Selection Options
This is an implicit field with only one option, Entire Table with Specific Columns.
Criteria*
Choose the element locator from the drop down list.
Criteria value
Provide the value of the element locator to search with.
Element index
You may also select option FIRST if you want first element from the located element and select LAST if you want last element.
Get Values Table:
Table Column Index
Specify column index to be retrieved. For multiple columns, mention column index on different rows.
8
Output Field Name
New field to store the retrieved value of the respective column for each row.
Loop Tab:
Conditional Loop?
Checkbox to activate the Conditions block, else Number of rows will is active.
Number of rows
Specify the number of rows to pass through the loop. Values are in a dropdown,
  1. All Rows
  2. First
  3. Last
Also a text box is provided to enter a numeric value N, in case First or Last is selected.
Table: Additional Fields
This table is used to create user defined additional fields. Additional fields are added as columns to the row. They are permanent and visible even after the loop is over.
Note: Any fields created within a loop are not permanently available after loop execution. Only Additional fields specified in Loop Start are available even after loop execution.
Name
Provide names of all additional fields you want to define.
Type
Select a data type for the additional field.
Format
Select a format for the data Type selected above.
Default value
Provide a default value for the additional field.
Set empty string?
Select Y or N.
If default value is not provided set ‘Set empty string?’ to Y. This sets a null value as an empty string.
8
Block: Conditions
For more detailed description with screen shots refer Start Loop step.
Conditions Block is a set of five fields. These fields can be populated with Previous field, Addition fields or Static values.  Click the field to populate a value as a toggle or from a popup that comes up.
The first field specifies a toggle for a condition. Leave it default to blank or click once to toggle it to NOT.
The second is the field to compare.
The third field is an operator
The fourth field is the field to be compared against or alternately specify a static value in the sixth field to be compared against.
Click on the small rectangular icon on the right hand side of the block to add a condition. You can Add a condition with the following operators: OR, AND, OR NOT, AND NOT, XOR.
Multiple condition list by icon on right side
Right click on a condition to get a pop-up menu with the following options: Edit condition, Delete condition, Add sub-condition, Move condition to sub-condition (-->), Move condition to parent (<--) and more copy options. These options can be used to create Nested conditions.
9
Button: Get Fields
In the Conditions Block above only previous fields are available. Click Get Fields to make Additional fields also available in the conditions block.
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Table
The Web Table step is used to traverse through HTML table in Web GUI automation. Either entire table or specific columns can be the output.
No
Web Browser Name
Selection Options*
There are three options to iterate through entire table or specific row with specific columns.
Criteria**
Locate element on web page.
Criteria value
Relevant criteria value to be specified.
Element index
Table Column Index
8
Output Field Name
Field to store the retrieved value of the respective column.
*Selection Option
The table below contains the description of each Selection Option.
No
Entire Table With Specific Columns
Traverse entire table and retrieve values from specific column(s).
One Row With Specific Columns
Retrieve one row with specific column(s).
One Cell
Retrieve value of one column of any specific row.
**Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Page Scroll
The Web Page Scroll step is used to scroll a web page in Web GUI automation. It can be used to locate or access an element on the web page which requires page scrolling. Criteria and value are specified to locate the element to scroll to and the step will automatically scroll where ever needed.
No
Web Browser Name
Criteria*
Criteria value
Element index
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Set Delay
The Web Set Delay step sets the global delay value for further steps in Web GUI automation.
No
Web Browser Name
Global delay value to be set for the specified driver.
No
Common Buttons
Help
OK
Cancel
Web Set Retry Count
Web Set Retry Count step is used to modify the Retry Count specified in Start Browser of Web GUI automation. Steps after Web Set Retry Count will get newly set Retry Count.
No
Web Browser Name
Retry Count
A retry count number can be set that is globally used in all steps of WEBGUI for retrying on error. Initially a retry count number can be set in Start Browser step. Whenever the execution of web gui step ends up with an error it will retry execution the number of time specified in start browser.
If one does’nt want to retry for some specific steps, retry count can be set to 0 by using ‘Set Retry Count’ Step.  Use of ‘Web Set Retry Count’ is to modify the count specified in Start Browser. Steps after Web Set Retry Count will get newly set Retry Count.
  1. Begin
  2. End
  3. CloseWindow
  4. Robot Handling
  5. SetDelay
  6. SetRetryCount
  7. URL navigation
No
Common Buttons
Help
OK
Cancel
Web Set Value
The Web Set Value step is used to set the text in the web element, example, text box, column in a table in Web GUI automation.
No
Web Browser Name
Criteria*
Criteria value
Text
Here you can specify the text you want to enter in to the element you have located.
Clear text before set?
Select Yes if you want to remove previously set value in the element you have located and No if you want to append the text in the element.
 *Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Switch Frame
The Web Switch Frame step switches between HTML frames in the web page in Web GUI automation.
No
Web Browser Name
Locate By*
Switching frame options
Criteria*
Criteria Value
Element index
*Locate By
The table below contains the description of each Locate By option.
No
Default
Navigate to default context of the page i.e. outer most region of web page
Parent
Navigate to parent frame
Name
Specify name of the frame to switch to
Id
Specify id of the frame to switch to
Element
Switch to frame where element of specific criteria is present
Index
Index of the frame you want to switch to
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web Switch Window
The Web Switch Window step is useful when you want to switch between multiple browser windows in Web GUI automation. This basically gives the handle of desired window to perform further activity on that window.
Configuration
No
Web Browser Name
Switching options*
Options to switch window
Criteria*
Locate element on web page. By default this field will be disabled and will be enabled only when Element is selected as a switching option.
Value
Relevant value for the specified Switching option.
*Switching Options
The table below contains the description of each Switching option.
No
Window Title
Option can be used when window title is known.
Element
Tries to find the specified element in all open browser windows and stops on the window where this element is found.
Criteria to locate element can be specified using criteria and value field.
URL
If there are multiple windows or tabs open in the browser with different URLs and you need to navigate to the window having specific URL. Specify URL in the value field.
Index
Every window open in the browser has the index starting from zero you can switch to any window using this index.
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
No
Common Buttons
Help
OK
Cancel
Web URL Navigation
The Web URL Navigation step is used for navigating to another URL on the same browser window in Web GUI automation.
No
Web Browser Name
Web URL
URL to navigate to.
Page load timeout.
No
Common Buttons
Help
OK
Cancel
Web Wait Until
The Web Wait Until step waits for an element to be visible, enabled or present on the web page in Web GUI automation. The maximum wait time is until the delay specified.
No
Web Browser Name
Expected Condition*
Specify the wait condition for the element
Maximum time in milliseconds to wait for the expected condition.
Criteria*
Criteria Value
*Expected Condition
The table below contains the description of each condition.
No
Alert present
Check if alert present.
Element visible
Check if element with specific criteria is visible.
Element present
Check if element with specific criteria is present.
*Criteria
No
Xpath
Id
Name
Link Text
Partial Link text
Tag Name
Class Name
8
Css Selector
Notes: If Expected condition is ‘Alert present’, the Criteria and Criteria value fields are disabled.
No
Common Buttons
Help
OK
Cancel
