the usage of Element is dropdown Property of Web get Value Step, but could not find the appropriate output for the same. It is fetching the first value from the drop-down by default whether we select 'Element is dropdown' Yes or No.
Would like to know how it does or in Which scenario we should use that as we already have Web Dropdown Step.
For this, You have to select the value from a dropdown first then only it will get the value.
Please find the attached workflow for reference.
