Unable to send mail and attachment using Send Email Step--specified filename not found
Unable to send Emails and attachments using the Send Email Step. After execution it is giving an error: specified filename not found and if execute it without attachment it gives the error: Unable to send an email. (Refer to the screenshot below). The agent and File to be attached are on the same machine.
Used a runtime parameter to specify the filename to be attached & tried to give the file name as String and File Data type.
Also, SMTP is configured and working fine.
Solution: Please find the attached sample workflow.
