Unable to open Chrome in Process Studio / AE Server
Issue
(Session info: chrome=73.0.3683.103)
(Driver info: chromedriver=73.0.3683.68 (XXXXXXXXXXXXXXXXXXX),platform=XXXXXXXXXXXXXXXXXXXXX) (WARNING: The server did not provide any stacktrace information)
Command duration or timeout: 10 milliseconds
Build info: version: '2.53.1', revision: 'XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX', time: '2016-06-30 19:26:09'
System info: host: 'serverhostname', ip: 'XXXXXXXX', os.name: 'XXXXXXXX', os.arch: 'amd64', os.version: 'XXX', java.version: '1.8.0_191'
Driver info: org.openqa.selenium.chrome.ChromeDriver
How to Reproduce:
You can navigate to folder WEB-GUI/webui_drivers and delete one of the existing Google chrome version driver to reproduce this issue.
Solution
- Check if you have the latest version of Plugin
- Check if the Brower version you are using, the driver is in WEB-GUI/webui_drivers
- Same goes for Linux check the driver is in WEB-GUI/webui_drivers/linux.
Or else you can upgrade the Latest version of Chrome Browser and test the same.
