Process Studio Login Failure with the SSO user Due to Azure AD Reply URL Mismatch (AADSTS50011)
Warning
Issue :
Users were unable to login to Process Studio using SSO authentication and encountered the below error from Azure AD:
AADSTS50011: The reply URL specified in the request does not match the reply URLs configured for the application.
Additionally, Process Studio logs showed:
  • Authentication : HTTP Status - 400
  • SSO Callback server started on port 2611
Alert
Error Message :
AADSTS50011: The reply URL 'http://localhost:2611/callback' specified in the request does not match the reply URLs configured for the application.
Environment
  • Process Studio Version: 8.4.0
  • Authentication Protocol: SAML 2.0
  • Identity Provider: Microsoft Azure AD
Info
Root Cause :
Process Studio uses a local callback server during the SSO authentication flow and sends the below redirect URI during login:
However, this URL was not configured in the Azure AD application Reply URL/Redirect URI settings. Due to this mismatch, Azure AD rejected the authentication request and returned HTTP 400 with error code AADSTS50011.
Observations from Logs
This confirmed that:
  • Process Studio started successfully.
  • The local SSO callback server was running correctly.
  • Authentication failed at Azure AD validation stage due to redirect URI mismatch.
Idea
Solution :
Add the localhost callback URL in the Azure AD application Reply URL/Redirect URI configuration.
Required Redirect URI
Steps to Configure in Azure AD
  1. Login to Azure Portal.
  2. Navigate to:
    Azure Active Directory → App Registrations
  3. Open the required application.
  4. Go to:
    Authentication
  5. Under Redirect URIs / Reply URLs, add:
  6. Save the configuration.
  7. Restart Process Studio and retry login.
Result
After adding the localhost callback URL in Azure AD:
  • SSO login started working successfully.
  • Users were able to authenticate in Process Studio without errors.
Additional Notes
  • The Redirect URI must match exactly.
  • Ensure no firewall or proxy restrictions block localhost port 2611.
  • Browser cache/session cleanup may be required after configuration changes.
