This Knowledge Article is to know how to log in to SAP without using plugin (POC) as per the clients requirement.
It has the simple scenario that has been executed using VB script mentioned in the steps below:
- Set credentials as parameters and pass that to set SAP path (the .exe path) using the Java Class
- Write a VB script to Log in to SAP using credentials & test it (without using SAP plugin)
- Then you can write VB script to Log out of the same.
Basically this POC was an IN & OUT procedure to LOG IN and LOG OUT of the SAP without using the plugin and that has been successfully done by the workflow provided by Sachin Deshpande.
You can find the Workflow in the ticket #3174 or you can find the Workflow attached to this Article
