Salted Hashing Issue – Configuration(7.7.4)
Objective
To prevent password replay attacks by restricting reuse of encrypted credentials within a defined time window.
Issue
Encrypted passwords can be reused, leading to a potential password replay attack.
Affected Module
  • Module: AppSec
Impact
  • Encrypted passwords do not expire immediately after login
  • Reusable encrypted credentials can allow unauthorized access
Solution
Configuration File
<AE_Application>/conf/ae.properties
Add/Update Below Properties
ae.check.logintime=true
ae.logintime.window.seconds=10
Configuration Details
  • ae.check.logintime = true
    Enables login time validation
  • ae.logintime.window.seconds = 10
    Allows password reuse only within a 10-second window (handles clock drift)
Validation
  1. Restart AE server
  2. Perform login and capture encrypted request
  3. Attempt reuse after defined time window
Expected Result:
  • Login should fail after the configured time window
Next Steps
  • Apply the configuration changes
  • Restart the AE server
  • Validate using penetration testing
  • Monitor authentication logs for any anomalies
  • Ensure system time is synchronized across servers
  • Adjust time window based on client security requirements
