Resolving ADFS SAML SSO Error – ID4037: The Key Needed to Verify the Signature Could Not Be Resolved
NotesOverview :
Product: AutomationEdge On-Prem
Version Validated: AutomationEdge 8.2.5
Authentication: ADFS SAML Single Sign-On (SSO)
This article explains how to configure Microsoft Active Directory Federation Services (ADFS) with AutomationEdge using the SAML 2.0 protocol and provides troubleshooting steps for resolving the following authentication error:
ID4037: The key needed to verify the signature could not be resolved from the security key identifier. Ensure that the Security Token Resolver is populated with the required key.
This error generally occurs when AutomationEdge is unable to validate the SAML response received from ADFS due to one or more of the following:
  • Certificate mismatch between AutomationEdge and ADFS
  • Incorrect Entity ID (Identifier)
  • Incorrect SAML claim mappings
  • Outdated Federation Metadata (descriptor.xml)
  • Incorrect Single Logout configuration
Info
Prerequisites :
Before configuring SSO, obtain the following information from ADFS:
  • Identity Provider Metadata (descriptor.xml)
  • Client ID
  • Redirect URI(s)
  • Keystore File
  • Keystore Alias
  • Keystore Password
  • RSA Certificate (.crt)
To generate a Self-Signed or CA-signed certificate, refer to the Keystore and Certificate Generation guide.
Configure the Relying Party Trust
  1. Open AD FS Management.
  2. Navigate to Relying Party Trusts.
  3. Click Add Relying Party Trust.
  4. Select Claims Aware.
  5. Choose Enter data about the relying party manually.
  6. Enter a display name.
  7. Skip the certificate configuration (it will be configured later).
  8. Enable SAML 2.0 WebSSO Protocol.
  9. Enter the AutomationEdge Redirect URL (HTTPS).
Example:
https://<AutomationEdge-Server>/aeui/index.jsp
  1. Configure the Identifier (Entity ID).
  2. Complete the wizard.
  3. Select Configure Claims Issuance Policy before closing the wizard.
Validation
Verify that the Entity ID (Identifier) configured in AutomationEdge is exactly the same as the Identifier configured in the ADFS Relying Party Trust.
Common Issue
The Entity ID configured in AutomationEdge does not match the Identifier configured in ADFS.
Resolution
Update the Identifier in AutomationEdge so that it exactly matches the Identifier configured in ADFS.
Configure Claim Rules
Rule 1 – Send LDAP Attributes as Claims
Select:
  • Claim Rule Template
    • Send LDAP Attributes as Claims
Attribute Store:
Active Directory
Configure the following mappings:
LDAP AttributeOutgoing Claim
User-Principal-Nameusername
E-Mail-AddressesemailAddress
Given-NamefirstName
SurnamelastName
Rule 2 – Transform Incoming Claim
Select:
  • Incoming Claim Type
    • UPN
  • Outgoing Claim Type
    • Name ID
  • Outgoing Name ID Format
    • Unspecified
Finish the wizard.
Validation
AutomationEdge expects the outgoing claim names exactly as shown below.
The values are case-sensitive.
username
emailAddress
firstName
lastName
Common Issue
Claim names were configured with incorrect capitalization or different names.
Examples:
UserName
Email
Firstname
Last_Name
Resolution
Update the claim names to:
username
emailAddress
firstName
lastName
Upload the RSA Certificate
  1. Open Relying Party Trust Properties.
  2. Navigate to the Signature tab.
  3. Click Add.
  4. Upload the RSA certificate.
  5. Click Apply.
Upload the Token Signing Certificate
  2. Navigate to Certificates.
  3. Upload the Token Signing Certificate.
  4. If multiple certificates exist:
    • Right-click the correct certificate.
    • Select Set as Primary.
Validation
Verify that:
  • The Token Signing Certificate configured in ADFS is the same certificate configured in AutomationEdge.
  • The correct certificate is marked as Primary.
Common Issue
AutomationEdge and ADFS were configured with different certificates.
As a result, AutomationEdge could not verify the SAML signature, resulting in the ID4037 error.
Resolution
  • Regenerate the certificates if necessary.
  • Upload the same certificates to both AutomationEdge and ADFS.
  • Set the correct Token Signing Certificate as Primary.
  • Re-test SSO.
Configure the Single Logout Endpoint
Navigate to:
Relying Party Trust → Properties → Endpoints
Add:
Endpoint Type
SAML Logout
Binding
POST
Trusted URL
https://<ADFS-Server>/adfs/ls/?wa=wsignout1.0
Response URL
https://<AutomationEdge-Server>/aeui/logout.jsp
Save the configuration.
Validation
Verify that the Logout URL configured in AutomationEdge matches the Logout endpoint configured in ADFS.
Common Issue
Incorrect Single Logout URL.
Resolution
Update the Logout URL to:
WS-Federation Configuration
The original ADFS configuration documentation includes a WS-Federation endpoint.
However, when only SAML authentication is being used, WS-Federation is not required.
Common Issue
WS-Federation endpoint configured unnecessarily.
Resolution
Remove the WS-Federation endpoint if only SAML authentication is used.
Configure WS-Federation only if your authentication flow explicitly requires it.
Verify Secure Hash Algorithm
Navigate to:
Relying Party Trust
    → Properties
        → Advanced
Ensure the Secure Hash Algorithm is configured as:
SHA-256
Update descriptor.xml
Whenever certificates are regenerated, download a fresh Federation Metadata file.
Open PowerShell:
Get-AdfsEndpoint
Locate the Federation Metadata endpoint.
Open the URL in a browser.
Save the XML as:
descriptor.xml
Upload the updated descriptor.xml into the AutomationEdge SSO configuration.
Validation
Whenever the Token Signing Certificate changes, upload a new descriptor.xml to AutomationEdge.
Common Issue
AutomationEdge was using an outdated Federation Metadata file.
Idea
Resolution :
Download a fresh descriptor.xml and upload it into the AutomationEdge SSO configuration.
AutomationEdge SSO Configuration
Configure the following under Settings → Single Sign-On:
  • Client ID
  • Redirect URI
  • Entity ID
  • Certificate
  • Keystore
  • Alias
  • Password
On the login page:
  1. Click Sign in with SSO.
  2. Enter the Organization Code.
  3. Authenticate using ADFS.
Validation Checklist
Before testing SSO, verify the following:
ConfigurationValidation
Entity IDMatches exactly between AutomationEdge and ADFS
Redirect URLHTTPS and correctly configured
Claim Namesusername, emailAddress, firstName, lastName
Token Signing CertificateSame certificate in ADFS and AutomationEdge
Primary CertificateCorrect Token Signing Certificate is set as Primary
Secure Hash AlgorithmSHA-256
Logout URLCorrect ADFS logout endpoint
descriptor.xmlLatest version uploaded after certificate changes
WS-FederationRemoved if not required
Idea
Resolution Summary :
The issue was resolved by performing the following actions:
  • Regenerated the certificates and synchronized them between AutomationEdge and ADFS.
  • Uploaded the correct Token Signing Certificate in ADFS.
  • Corrected the Entity ID mismatch.
  • Corrected the outgoing claim names to:
    • username
    • emailAddress
    • firstName
    • lastName
  • Updated the Single Logout URL.
  • Removed the unnecessary WS-Federation configuration.
  • Downloaded and uploaded the latest descriptor.xml after certificate regeneration.
Result
After applying the above configuration changes:
  • AutomationEdge successfully validated the SAML response received from ADFS.
  • The ID4037 signature verification error was resolved.
  • Users were able to authenticate successfully using ADFS SAML Single Sign-On (SSO).
  • SSO authentication completed successfully without further signature verification failures.
