Request from remedy not getting pull in AutomationEdge
AE version: 3.2.0
AE-remedy integration
Issues: Request from remedy not getting pull on AutomatonEdge
Error in automationedge.log file:
"javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target"
1. This error is related to the SSL certificates and to resolved this error we need to import this certificate on AutomationEdge.
2. These 3 (Root, intermediate, and CA-primary) certificates we need to import on cacerts file (present in C:\Program Files\Java\jre1.8.0_91\lib\security folder) using the below command.
Ø  keytool -import -trustcacerts -keystore $JRE_HOME/lib/security/cacerts -storepass changeit -alias Root -import -file root.txt
Ø  keytool -import -trustcacerts -keystore $JRE_HOME/lib/security/cacerts -storepass changeit -alias Root -import -file intergration.txt
Ø  keytool -import -trustcacerts -keystore $JRE_HOME/lib/security/cacerts -storepass changeit -alias Root -import -file primary.txt
3. After importing these certificates, restarted the tomcat service and check.
