Not able to login to AEUI on production server
Issue: Not able to login to AEUI.
Observations: As per the error, Audit logs were not getting saved, the reason being the drive was full, where Automationedge is installed. Due to which, you were not able to login to AEUI(server) & also the processes got stuck.
As per our suggestion, we recommend you to delete unwanted files and folders present In the drive as it consumes space needed to save logs.
RCA: After removing some unwanted files & folder from the drive, and deleting audit log data from the Postgres database, we were able to login to AEUI.
