ERROR BaseStep:2951 - Can't run workflow due to plugin missing
Error when executing the Workflow on AE Server: ERROR BaseStep:2951 - Can't run workflow due to plugin missing.
How to Reproduce:
You can delete the PS plugin folder or sub folder in Agent Folder to reproduce the same issue.
Solution :
1. Remove all the workflow assignments from your Existing agent hence the PSPlugins folder will be empty.
2. Assign one workflow to your Existing agent.
3. Hence the plugins in psplugins folder have been created successfully and processes will run properly.
