You can develop workflow with Machine Learning using the steps below:
Access Needed:
Must have T3/OnDemand/On-Premises
For T3/OnDemand, you need to contact support and activate Machine learning.
For On-Premises, you need to download Latest Plugin Distribution and upload it on the Server with Sysadmin user.
Steps:
After doing so, please follow the steps below:
- You need to follow the prerequisites given in Plugin Reference Guide on the Resources Tab Under Machine Learning Plugins
- Specifically use this python and follow the instructions from step 1. (Run CMD as Admin when running commands)
- Sync plugins from Process Studio Tools Menu, PS will sync and restart and Voila! You now have working ML plugins!
You can now develop a Workflow with the Machine Learning plugin.
