Article Unicode Characters Appearing Incorrectly in Process Studio (MJSV)
🔹 Issue Summary
A reported an issue while retrieving address data from the database and copying it into Modified JavaScript Value (MJSV) in Process Studio.
The value stored in the database:
27239 HIGHWAY 42 AРТ В
However, when used in Process Studio, it appears incorrectly due to Unicode conversion:
27239 HIGHWAY 42 APT. B
🔹 Impact
  • The Surface Automation Plugin fails to set the full value correctly
  • Only partial value is entered:
27239 HIGHWAY 42 A
  • The expected value:
  • This leads to data inconsistency and automation failure
🔹 Root Cause
The issue occurs due to Unicode characters (Cyrillic letters) that visually resemble ASCII characters.
Example:
CharacterLooks LikeActual Encoding
РPCyrillic
ТTCyrillic
ВBCyrillic
👉 These characters are not standard ASCII, causing:
  • Misinterpretation in MJSV
  • Incorrect behavior in Surface Automation Plugin
🔹 Solution / Workaround
This is a known issue, and a workaround is available using JavaScript.
✅ Option 1: Unicode to ASCII Converter
Use the attached script:
unicode_to_ascii_converter.txt
🔹 Function:
  • Converts Unicode characters to their ASCII equivalents
✅ Option 2: Unicode Character Handling Script
Unicode_Character_Handling.txt
🔹 This script performs:
  • Detects Unicode characters
  • Splits string into segments
  • Retains only ASCII parts
  • Counts segments
  • Outputs cleaned data in JSON format
🔹 Implementation Steps
  1. Add User Defined JavaScript / MJSV step
  2. Import or paste the provided script
  3. Pass input string from database
  4. Apply conversion logic
  5. Use cleaned output for:
    • Surface Automation Plugin
    • Further processing
🔹 Conclusion
The issue is caused by Unicode lookalike characters, not visible differences.
Using the provided JavaScript workaround ensures:
  • Correct ASCII conversion
  • Proper value handling in Process Studio
  • Successful execution of Surface Automation steps
📎 Attachments
  • unicode_to_ascii_converter.txt
  • Unicode_Character_Handling.txt
