java.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory
AE Version: 6.0
Error in logs:
javax.xml.bind.JAXBException: Provider com.sun.xml.internal.bind.v2.ContextFactory not found - with linked exception:
[java.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory cannot be found by com.my.cep.studio.cluster.topology_0.0.0]
!ENTRY com.my.cep.diagramming 4 0   at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:146)
    at javax.xml.bind.ContextFinder.find(ContextFinder.java:289)
    at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:412)
    at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:375)
    at com.my.cep.studio.cluster.topology.editors.ClusterTopologyDiagramManager.parseFile(ClusterTopologyDiagramManager.java:193)
    at com.my.cep.studio.cluster.topology.editors.ClusterTopologyDiagramManager.openModel(ClusterTopologyDiagramManager.java:175)
    at com.my.cep.diagramming.drawing.BaseDiagramManager.createDrawingCanvas(BaseDiagramManager.java:233)
    at com.my.cep.diagramming.drawing.DiagramManager$2.run(DiagramManager.java:259)
    at java.desktop/java.awt.EventDispatchThread.run(EventDispatchThread.java:90)
Caused by: java.lang.ClassNotFoundException: com.sun.xml.internal.bind.v2.ContextFactory cannot be found by com.my.cep.studio.cluster.topology_0.0.0
    at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:512)
    at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:423)
- You will face this issue mostly in "User Definded Java Class" plugin of PS-6.0.
- The reason of this error is, Sun people have remove directly access to JAXB package in java 11. These packages are availble in Java 8.
- To resolve this issue, you need to add below dependencies in your code manually.
<dependency>
    <groupId>com.sun.xml.bind</groupId>
    <artifactId>jaxb-core</artifactId>
    <version>2.3.0.1</version>
</dependency>
<dependency>
    <groupId>javax.xml.bind</groupId>
    <artifactId>jaxb-api</artifactId>
    <version>2.3.1</version>
</dependency>
<dependency>
    <artifactId>jaxb-impl</artifactId>
</dependency>
<dependency>
    <groupId>org.javassist</groupId>
    <artifactId>javassist</artifactId>
    <version>3.25.0-GA</version>
</dependency>
