Workflow schedular with parameter of type FILE not supported in AE
Description:
If you have a configured a process/workflow in which you have used runtime parameter type as FILE, then this process works fine when you submit a request from Catalauge but if you create a Schedular for this process then it will not work.
This is a limitation in AE, workflow schedular with a parameter of type FILE not supported in AE
