How to download Request Output file from AE Server using REST API.
Advance Rest client: Advanced REST Client is a step in the utility Plugin for Process Studio Workflows. The REST Client workflow step enables you to consume RESTful services by making REST calls.
JSON: JSON input is a step in the Input Plugin for Process Studio Workflows. The JSON Input step plugin step can read relevant portions out of JSON structures dynamically from field values in the stream or parameters, referring to files or Urls. Secondly, users can also define files and Urls as static values. The step outputs portions out of JSON structures as rows.
Please find the attached sample workflow.
