How to configure proxy settings to run desktop application
- To configure the proxy settings in desktop plugin, goto the process-studio-5.6.0\psplugins\DesktopPlugins\desktop-engine\userdata\config or aeagent\psplugins\DesktopPlugins\desktop-engine\userdata\config folder.
- Edit the userdata.properties file present in the above location
- Add your proxy settings to this file
for HTTP proxy:
# Use external proxy server for http
ext.http.proxy.enable=true
ext.http.proxy.host=
ext.http.proxy.port=
ext.http.proxy.auth.enable=false
ext.http.proxy.auth.encrypted=false
ext.http.proxy.auth.name=username
ext.http.proxy.auth.password=password
For HTTPS proxy:
# Use external proxy server for https
ext.https.proxy.enable=true
ext.https.proxy.host=
ext.https.proxy.port=
ext.https.proxy.auth.enable=false
ext.https.proxy.auth.encrypted=false
ext.https.proxy.auth.name=username
ext.https.proxy.auth.password=password
- After adding the details, restart process-studio/agent and check.
