Failed to update plugins on AE portal - No step or entry found in a plugin jar.
Error :
Refer below screenshot-
The above error occurs while uploading the plugins through sysadmin login on Automationedge portal due to Plugin and AutomationEdge version compatibility.
Resolution :
In this case, we need to check the plugin release version compatibility with the current AutomationEdge version and upload the plugins according to it.
For Example:
If you are using AutomationEdge version 6.0 then you need to upload the plugins in release version 2.0.
For more information, refer to the section plugin compatibility in plugin reference guide under the resource tab on AE portal.
