Failed to load: class path resource [activemq.xml]
Problem:
ActiveMQ is automatically stopped.
Error in log:
2019-02-26 10:35:01,222 | INFO  | Refreshing org.apache.activemq.xbean.XBeanBrokerFactory$1@d3f0053: startup date [Tue Feb 26 10:35:01 UTC 2019]; root of context hierarchy | org.apache.activemq.xbean.XBeanBrokerFactory$1 | WrapperSimpleAppMain
2019-02-26 10:35:02,600 | ERROR | Failed to load: class path resource [activemq.xml], reason: Line 54 in XML document from class path resource [activemq.xml] is invalid; nested exception is org.xml.sax.SAXParseException; lineNumber: 54; columnNumber: 48; cvc-complex-type.2.4.c: The matching wildcard is strict, but no declaration can be found for element 'pendingMessageLimitStrategy'. | org.apache.activemq.xbean.XBeanBrokerFactory | WrapperSimpleAppMain
1. Go to ActiveMQ install folder (Example - C:\ActiveMQ\conf\activemq.xml)
2. Open activemq.xml & check for extra ‘/’ as shown below
<destinationPolicy>
  <policyMap>
  <policyEntries>
     <policyEntry topic="> /" >
            <!-- The constantPendingMessageLimitStrategy is used to prevent
            slow topic consumers to block producers and affect other consumers
             by limiting the number of messages that are retained
             For more information, see:
            http://activemq.apache.org/slow-consumer-handling.html
            <pendingMessageLimitStrategy>
            <constantPendingMessageLimitStrategy limit="1000"/>
            </pendingMessageLimitStrategy>
            </policyEntry>
      </policyEntries>
    </policyMap>
</destinationPolicy>
 3.Remove the ‘/’ & Restart tomcat, Active MQ & Postgres services.
4. Login to Automation Edge UI.
