Exit code 9009 while starting agent
Error :
We get the error as below while start the agent i.e. EXIT_CODE is 9009
This happen when Java path is not set correcty.
How to reproduce:
- You can uninstall java or you can remove the system variables to reproduce the issue.
- You can install Java on your machine with correct version.
- Set the path of JAVA_HOME and JRE_HOME and try to start the agent again to resolve the issue.
