Issue
We get the below error when we use Execute a Shell Script Plugin.
This happens when you enter the character or character in a Parameter that is more than the Windows character Limit.
NOTE : The maximum length of the string that you can use at the command prompt / Plugin is 8191 characters. If the Character in the plugin is more than that, the process will fail.
How To Reproduce
You can enter the more than 8191 character / character in Parameter in the plugin to reproduce this issue.
Resolution
To resolve this kind of issue, we suggest to use 2 plugin instead of 1 plugin to execute more that 8198 characters.
