Exception in thread "main" java.lang.NoSuchFieldError: SIZE
Unable to start the agent. Gets an error message Exception in thread "main" java.lang.NoSuchFieldError: SIZE as below:
How to Reproduce:
Enable Automatically Detect proxy option from System Level and browser Level if you have proxy that blocks the agent to start to reproduce this issue.
You can ignore if you dont have proxy on your server.
- Remove Automatically Detect proxy option from System Level and browser Level and enter the proxy values MANUALLY
- Or disable the System Level proxy and browser Level Proxy completely if proxy is not used.
- Reinstall Agent and start as you normally do
