Error while uploading .XLSM file on AE server
Error in logs:
https-openssl-nio-443-exec-2 ERROR AEBaseRestController:37 - Invalid file format
https-openssl-nio-443-exec-2 ERROR AEBaseRestController:51 - Error Stack: com.automationedge.aeengine.rest.controller.FileController.uploadFile(FileController.java:115) com.automationedge.aeengine.rest.controller.FileController$$FastClassBySpringCGLIB$$ad2bf34b.invoke(<generated>) org.springframework.cglib.proxy.MethodProxy.invoke(MethodProxy.java:204)
Issue to Reproduce:
- Try to upload the .XLSM file on AE server.
-     Currently, we don’t support .XLSM file uploading on the AE server.
-     As a workaround, you can use this type of files directly from the stored location instead of passing it as a run-time.
