Error while starting agent : EXCEPTION_ACCESS_VIOLATION (0xc0000005)
Issue: Unable to start the agent.
ERROR:
Getting the error message in agent .log file as per below.
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000008f9b4856c4, pid=404, tid=0x00000000000011f8
# JRE version: Java(TM) SE Runtime Environment (8.0_261-b12) (build 1.8.0_261-b12)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.261-b12 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [sigar-amd64-winnt.dll+0x156c4]#
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
This issue has resolved after followed the below steps.
1. Installed the java 1.8.0_251
3. changes the variables path
4. Restart the machine
5. Try to start the agent.
