Error while setting up Remedy Integration setup on aeui console
AE-Remedy Integration
AE: 5.4.1
ERROR IntgServiceImpl:1398 - Remedy on demand, null: Integration Conf Test Connection failed as testConnection() method from type JAR returned false. Please check JAR code.
After removing below proxy settings from the server, the issue gets resolved:
1. Removed the proxy-configuration file from all the folders
2. Removed the system-level proxy from all the machines
3. Disabled the "Use automatic configuration script" from IE browser-->internet option-->Connection-->LAN settings from Integration machine
