Error: org.apache.http.conn.EofSensorInputStream@7c0660a6 ErrorCode – 500
Error
Resolution
1. Please refer minimum requirement for Cherwell 10.x & above and install the supported version of the SQL server.
3. Also, attached here is a Cherwell knowledge article where the root cause for this issue is mentioned. You can also find the knowledge article on https://zero.comaround.com/en-us/content/1357209/#/
4. Suggested to upgrade the minimum system requirements for Cherwell 10.x to resolve the issue.
5.  Also, Check  the output of the Swagger API URL /CherwellAPI/api/V1/getsearchresults –
