Memory release management is not done properly in workflow, which is causing heap size full. Due to that reason problem is coming while loading java Virtual machine.
Check if same workflow works fine in process studio. If yes then apply below changes.
1. Edit startup.bat and Increase Xmx2048 to Xmx4096 and save file.
2. Kill all task/process and instance from task manger which was occupied by JVM.
3.Submit request again.
