Error installing postgresql:While installing Postgres, problem running post-install step PostgreSQL windows 10, cluster initialization failed
Problem: An error occurred while installing Postgres SQL.
Error: While installing Postgres, problem running post-install step PostgreSQL windows 10, cluster initialization failed
1. Check the system32 path is set in the environment PATH variable. If not then follow the below step to set it.
Control Panel -> System -> Advanced System Settings -> Advanced -> Environment Variables
Under "System variable" find and select "Path"
Click "Edit..."
Append  system32 path to PATH variable (Example ";C:\Windows\system32")
2.  Reinstall Postgres SQL.
