Error: Hazelcast instance is not active!
The error was caused because Hazelcast crashed on the on-cloud instance. If you could see the following error in the log:
2023-02-09 12:37:21:585 UTC (Z) https-openssl-nio-443-exec-5 ERROR AEBaseRestController:145 - Exception:
com.hazelcast.core.HazelcastInstanceNotActiveException: Hazelcast instance is not active!
This typically occurs when Tomcat runs out of it’s allocated memory (Heap size)
 Traversing the logs in reverse, we could find the needed error:
2023-02-09 12:37:21:132 UTC (Z) https-openssl-nio-443-exec-6 ERROR IntgServiceValidationFilter:112 - Exception in IntgServiceValidationFilter java.lang.OutOfMemoryError: Java heap space
2023-02-09 12:37:21:148 UTC (Z) https-openssl-nio-443-exec-10 ERROR AEBaseRestController:145 - Exception:
org.springframework.web.util.NestedServletException: Handler dispatch failed; nested exception is java.lang.OutOfMemoryError: Java heap space
This is the same memory that we allocate Tomcat to run on. After upgrading Tomcat, it should not be too low for our application and an active instance.
 This could be considered as "one of the possible reasons“ for ‘Hazel instance not active’ error.
