Check if system is meeting below prerequisites mentioned in automationedge plugin reference guide:
1. Install Anaconda, Minimum version 4.2.0
2. No need for separate python installation, Anaconda takes care of python installation.
3. Anaconda should be in the PATH.
i. This can be conveniently achieved by enabling ―Anaconda in PATH‖ checkbox
during Anaconda installation else,
ii. Manually set Anaconda in the PATH environment variable by adding the
following to the path
iii. <ANACONDA_BASE>; <ANACONDA_BASE>\Library\mingw-w64\bin;
<ANACONDA_BASE>\Library\usr\bin; <ANACONDA_BASE>\Library\bin;
1.Paython 36 zip is required for latest plugin 'paython script 1.8 jar'.
