Difference between INFO and TRACE Level log
1.To understand difference,You need select 'log level' option from plugin 'Audit log' and upload workflow on server.
2.On AE, the Audit information is present on the Logs-> Audit log tab.
Here at Object_Name and Description are displayed variable/field name and its value respectively.
3.We have also provided the option to download the Audit logs on AE.
INFO logs are used for basic information on the variable and fields and TRACE logs are displayed more detailed logs.
