Issue
Issue when running WF on Agent:
Desktop Start ERROR SahiEngine:64 - java.net.ConnectException: Connection refused: connect”.
How To Reproduce:
- Remove the system proxy mentioned in Sahi in the path below:
Agent path /psplugins/DesktopPlugin/desktop-engine/userdata/config/userdata.properties
Resolution
This issue occurs when the proxy is not set in userdata.properties file or if there is a product key in the below path.
- Kindly remove the productkey.txt file from the path as below:
- Edit the system proxy mentioned in Sahi in the path below:
