button no action is happening on the backend/No error on AEUI as well.
Workaround:
- Create new Schedule with Schedule-type= Monthly
- Select only January or any other 1 month from the Monthly option and fill all other required details.
- Click on Submit button, it will not create the scheduler and not throw any error
- Now from the same Schedule select the Monthly option and select the Months as per your requirement and then click on Submit button. It will create the Schedule as per your requirement.
- Once Schedule get created and if you want do some changes in the same schedule then you can Edit the schedule and add the changes as per your requirement.
This bug will fix in the next AE release.
