com.automationedge.common.ext.integration.AeIntegrationTypeException: The required configuration parameters are not present i.e. URL, Username and Password, if not empty.
AE-Remedy Integration
Error in integration logs:
2021-06-14 14:45:00 IST (+05:30) DefaultQuartzScheduler_Worker-8 ERROR IntgServiceHandler:103 - ABG, <Remedy Request>, Error polling automation requests
at com.ae.intg.rod.RodIntegrationController.generateAccessToken(RodIntegrationController.java:219) ~[?:?]
Issue to Reproduce:
- Provide incorrect remedy URL at a time of Integration configuration on AE server.
- Check all the parameter provided in the Integration configuration on the AE server
- Try to access the provided remedy URL with the same port on the machine where the integration service is running.
- After providing the correct URL, Port, Username and Password, this issue will get resolved.
