Appendix 18: OneDrive Folder/File - Path
Get Folder Path
Following are the steps to get Folder Path,
  1. Open your One Drive.
  1.   |
    Click the Show actions icon () and select Details in the pop-up menu.
  1. Alternatively, right click on the folder and select Details.
  1. Thirdly, you may click on the ‘Open the details pane’
  1. In the details pane navigate to the bottom and click the ‘Copy direct link’ icon for the Path.
  1. In this case the folder path appears as follows,
https://automationedge1-my.sharepoint.com/personal/seema_kothari_automationedge_com/Documents/Test
  1. In the OneDrive plugin steps:
  1. Refer the root folder as:  Documents/
  2. Refer a folder in the root as:  Documents/<a sub-folder under root>
  3. Refer a sub folder in the root as:
    1. Documents/<a sub-folder1 under root>/<a sub-folder2>
    2. or simply
Get File Path
Following are the steps to get File path,
  1. Navigate to the desired file on OneDrive.
  1. Follow one of the methods to go to the details pane as described for folders in the previous section.
  1. Copy the Path URL.
  1. Following is a sample File path URI.
https://automationedge1-my.sharepoint.com/personal/seema_kothari_automationedge_com/Documents/Test/Numbers.xlsx
  1. Rrefer the root folder as:  Documents/
  2. Refer a file in the root as:  Documents/<a filename under root>
  3. Refer a sub folder in a sub-folder as:
    1. Documents/<a sub-folder1 under root>/<a filename>
    2. or simply
