Amazon EC2
Amazon EC2
Amazon EC2
Amazon EC2 plugin steps perform Amazon EC2 Virtual Machine operations.
Steps to Create Access Key ID and Secret Access Key:
Access Key and Secret Key are required for all Amazon EC2 Plugin steps.
Log in to your Amazon AWS Console (https://console.aws.amazon.com) and follow the below procedure to create Access Key and Secret Key.
  1. Click on the AWS logged in username in the top right side.
  2. Click on ‘My Security Credentials’.
  3. Click on ‘Access keys (access key ID and secret access key)’.
  4. Click on ‘Create New Access Key’.
  5. Your keys are now created. Either click on ‘Show Access Key’ to see the generated keys or Click on ‘Download Key File’ which contains the keys.
Amazon EC2: Get Instance Propoerties
Amazon EC2: Get Instance Properties step fetches the properties of all EC2 instances on the specified Amazon AWS cloud account.
Prerequisites:
  1. Amazon AWS cloud instance with access details.
  2. Login details [Access key and Secret key] to authenticate to Amazon AWS cloud. Refer “Steps to Create Access Key ID and Secret Access Key” in the Plugin header for details.
Note: As this step generates multiple rows, use this as the first step in the workflow
Step Name
Name of the step. This name has to be unique in a single workflow.
Connection:
Region
Specify the region where the instance is hoisted or choose a region from the Region Explorer window.
Button: Get
Click Get button to open the Region Explorer window. Choose a Region.
Access Key
Specify an Access Key to authenticate EC2 instance on Amazon AWS cloud. This field is mandatory.
Secret Key
Specify a Secret Key to authenticate Amazon AWS cloud.
8
Button: Test Connection
Click Test Connection button to verify whether the connection is available or not. Region, Access key and Secret Key are mandatory to authenticate Amazon AWS cloud.
For the purpose of verification fields coming from previous steps are not allowed since field values can only be accessed when workflow is in running state. Static (hardcoded) values and environment variables are allowed.It will not work for previous step fields.
Output Tab:
Output Fields (Tabular):
On click of the cell in the output table, if the connection is successfully established, it populates the list of instance properties.
Select an instance property in a field or many in the table as desired.
Output Field
Specify an output field to hold the field values for the field name specified above.
Amazon EC2: Launch Instance
Amazon EC2: Launch Instance plugin step launches an EC2 instance on the specified Amazon AWS cloud account.
Prerequisites
Login details [Access key and Secret key] to authenticate to Amazon AWS cloud. These can be found under AWS Management Console User Icon Security Credentials navigation. Refer “Steps to Create Access Key ID and Secret Access Key” in the Plugin header for details.
Step Name
Connection:
Region
Specify the region where the instance is hosted or choose a region from the Region Explorer window.
The field type is String. This field is mandatory.
Button: Get
Access Key:
Access key to authenticate Amazon AWS cloud.
Accept Values from fields
Leave checkbox unchecked to accept Access Key value from a field in the previous steps of the stream using a drop down list.
Else enable checkbox for Access Key field to appear as Text box.
Access Key
Specify the Access Key to authenticate Amazon AWS cloud EC2 instance.
If checkbox above is enabled Access Key field appears as Text box and accepts static values or variables. Else if checkbox above is disabled Access Key field appears as a drop down to select fields from previous steps.
Secret Key:
Secret key to authenticate Amazon AWS cloud.
Leave checkbox unchecked to accept Secret Key value from a field in the previous steps of the stream using a drop down list.
Else enable checkbox for Secret Key field to appear as Text box.
Secret Key
Specify the Secret Key to authenticate Amazon AWS Cloud EC2 instance.
If checkbox above is enabled Secret Key field appears as Text box and accepts static values or variables. Else if checkbox above is disabled Secret Key field appears as a drop down to select fields from previous steps.
8
For the purpose of verification fields coming from previous steps are not allowed since field values can only be accessed when workflow is in running state. Static values and environment variables are allowed.
Input Tab:
Input Fields:
Amazon Machine Image
Specify Amazon Machine Image (AMI) Id to be launched.
Instance Type
Specify Instance Type of the AMI to be launched.
Button: Get
Click Get button to get a popup containing list of Instance types.
Number of Instances
Specify Number of instances to be created.
Security Group
Specify Security Group in which instance is to be launched.
Button: Get
Click Get button to get a popup containing list of Security Groups.
Key Pair Name
Specify Key Pair Name to be assigned to the instance.
8
Button: Get
Click Get button to get a popup containing list of Key Pair Names.
Tip: You may use Get Instance Properties as the first step in the workflow to fetch these properties for all the EC2 instances on this AWS cloud account other than fetching them manually from EC2 web portal.
Output Tab:
Output Field:
Instance Id
Specify an output field to hold the Instance Id of the newly created Virtual Machine instance launched as a result of step execution.
Amazon EC2: Reboot Instance
Amazon EC2: Reboot Instance plugin step reboots an EC2 instance on the specified Amazon AWS cloud account.
Prerequisites
Login details [Access key and Secret key] to authenticate Amazon AWS cloud.
Refer “Steps to Create Access Key ID and Secret Access Key” in Plugin header for details.
Step Name
Connection:
Region
Button: Get
Access Key:
Access Key
Secret Key:
Secret Key
8
Input Tab:
Input Fields:
Instance Id
Specify the EC2 Virtual Machine Instance Id to be restarted.
Amazon EC2: Start Instance
Amazon EC2: Start Instance plugin step is designed to start an EC2 instance on the specified Amazon AWS cloud account.
Prerequisites
Step Name
Connection:
Region
Button: Get
Access Key:
Access Key
Secret Key:
Secret Key
Input Tab:
Input Fields:
Instance Id
Specify the EC2 Virtual Machine Instance Id to be started.
Output Tab:
Output Field:
Current State
Specify an output field to hold the current state of the instance after successful plugin execution. Default value for this field is “CurrentState”.
Current State label value is mandatory.
Previous State
Specify an output field to hold the previous state of the instance before successful plugin execution. Default label value for this field is “PreviousState”. Previous State label value is mandatory.
Amazon EC2: Stop Instance
Amazon EC2: Launch Instance plugin step stops an EC2 instance on the specified Amazon AWS cloud account.
Prerequisites
Step Name
Connection:
Region
Button: Get
Access Key:
Access Key
Secret Key:
Secret Key
8
Input Tab:
Input Fields:
Instance Id
Specify the Virtual Machine Instance Id to be stopped.
Output Tab:
Output Field:
Current State
Previous State
Amazon EC2: Terminate Instance
Amazon EC2: Terminate Instance plugin step terminates an EC2 instance on the specified Amazon AWS cloud account.
Prerequisites:
Login details [Access key and Secret key] to authenticate Amazon AWS cloud.​
Step Name
Connection:
Region
Button: Get
Access Key:
Access Key
Secret Key:
Secret Key
8
Input Tab:
Input Fields:
Instance Id
Specify the EC2 Instance Id to be terminated.
Output Tab:
Output Field:
Current State
Previous State
