Agent Controller Issue
 Unable to get the Session status.
2023-03-21 10:37:08 IST (+05:30) pool-2-thread-2 INFO  AEAgentWFHandler:228 - Initiating the session request
2023-03-21 10:37:08 IST (+05:30) Thread-8 INFO  FetchJob:88 - No job found for execution
2023-03-21 10:37:08 IST (+05:30) pool-2-thread-2 INFO  QueryCommandParser:108 - Query Process Exited With Code: 1
2023-03-21 10:37:08 IST (+05:30) pool-2-thread-2 INFO  QueryCommandParser:49 - Unable to get the Session status
java.lang.IndexOutOfBoundsException: Index 0 out of bounds for length 0
                at jdk.internal.util.Preconditions.outOfBounds(Unknown Source) ~[?:?]
                at jdk.internal.util.Preconditions.outOfBoundsCheckIndex(Unknown Source) ~[?:?]
                at jdk.internal.util.Preconditions.checkIndex(Unknown Source) ~[?:?]
                at java.util.Objects.checkIndex(Unknown Source) ~[?:?]
                at java.util.ArrayList.get(Unknown Source) ~[?:?]
                at com.automationedge.aeagent.util.QueryCommandParser.getActiveSession(QueryCommandParser.java:55) ~[aeagent-7.4.1.jar:?]
                at com.automationedge.aeagent.util.QueryCommandParser.getActiveRDPSession(QueryCommandParser.java:47) [aeagent-7.4.1.jar:?]
                at com.automationedge.aeagent.util.common.AgentUtil.startAndWaitForRDP(AgentUtil.java:71) [aeagent-7.4.1.jar:?]
                at com.automationedge.aeagent.core.handlers.AEAgentWFHandler.doExecute(AEAgentWFHandler.java:231) [aeagent-7.4.1.jar:?]
                at com.automationedge.aeagent.core.handlers.WorkflowHandler.run(WorkflowHandler.java:39) [aeagent-7.4.1.jar:?]
                at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
                at java.lang.Thread.run(Unknown Source) [?:?]
How To Reproduce:
Make username of more than 15 character.
Please check the below command on agent machine.
  Command: query session <user_name>
It will generate output similar to the image below.
Need user name length less than 15 characters.
