Summary:
This issue is basically with the ActiveMQ services it was not in running mode. In the logs, please check that the 61616 port has been busy or not.
ERROR:
java.io.IOException: Transport Connector could not be registered in JMX: java.io.IOException: Failed to bind to server socket: tcp://0.0.0.0:61616?maximumConnections=1000&wireFormat.maxFrameSize=104857600 due to: java.net.BindException: Address already in use: JVM_Bind
at org.apache.activemq.util.IOExceptionSupport.create(IOExceptionSupport.java:28)[activemq-client-5.15.8.jar:5.15.8]
Steps followed:
1. For this purpose, we have changed the port number in two files.
activemq.xml
ae.properties
2. We have changed the port to 61616 to 61617 in the both of the above files."
