ActiveMQ: Enable JMX with authentication
PART 1: ActiveMQ Broker Authentication (Mandatory)
Objective
  • Enforce username/password authentication
  • Disable anonymous access
  • Encrypt credentials at rest
Step 1: Encrypt the ActiveMQ Password
Open Command Prompt as Administrator and navigate to the ActiveMQ bin directory:
cd <ACTIVEMQ_HOME>\bin
Run the encryption command:
activemq encrypt --password activemq --input <your_password>
Example:
activemq encrypt --password activemq --input snehal
Sample Output:
Encrypted text: sUBa0wl6rQQeW8HU6TFIUw==
Note: Save the encrypted value. It will be used in configuration files.
Step 2: Configure Encrypted Credentials
File:
<ACTIVEMQ_HOME>\conf\credentials-enc.properties
Add or update the following entries:
aeuser.password=ENC(sUBa0wl6rQQeW8HU6TFIUw==)
activemq.username=admin
activemq.password=ENC(sUBa0wl6rQQeW8HU6TFIUw==)
Step 3: Remove Default Plain-Text Placeholder (CRITICAL STEP)
File:
<ACTIVEMQ_HOME>\conf\activemq.xml
❌ REMOVE the following block completely (if present):
<bean class="org.springframework.beans.factory.config.PropertyPlaceholderConfigurer">
    <property name="locations">
        <value>file:${activemq.conf}/credentials.properties</value>
    </property></bean>
Why this step is mandatory
  • Loads plain-text credentials
  • Conflicts with encrypted properties
  • Prevents password decryption
  • Causes authentication failures
Step 4: Enable Encrypted Property Support (Jasypt)
File:
Add the following Spring beans under <beans>:
<bean id="environmentVariablesConfiguration"class="org.jasypt.encryption.pbe.config.EnvironmentStringPBEConfig">
    <property name="algorithm" value="PBEWithMD5AndDES"/>
    <property name="passwordEnvName" value="ACTIVEMQ_ENCRYPTION_PASSWORD"/></bean>
<bean id="configurationEncryptor"class="org.jasypt.encryption.pbe.StandardPBEStringEncryptor">
    <property name="config" ref="environmentVariablesConfiguration"/></bean>
<bean id="propertyConfigurer"class="org.jasypt.spring4.properties.EncryptablePropertyPlaceholderConfigurer">
    <constructor-arg ref="configurationEncryptor"/>
    <property name="location" value="file:${activemq.conf}/credentials-enc.properties"/></bean>
Step 5: Enable Broker Authentication
Inside the <broker> section of activemq.xml, add:
<plugins>
    <simpleAuthenticationPlugin anonymousAccessAllowed="false">
        <users>
            <authenticationUserusername="admin"password="${aeuser.password}"groups="admins,users"/>
        </users>
    </simpleAuthenticationPlugin></plugins>
✔ Anonymous access disabled
✔ Authentication enforced
Step 6: Set Encryption Secret (OS Level)
Set the encryption password as a SYSTEM environment variable:
setx ACTIVEMQ_ENCRYPTION_PASSWORD "activemq" /M
Important: Restart the server or ActiveMQ service after setting this variable.
Step 7: Configure AutomationEdge
File:
<AE_HOME>\ae.properties
Add or verify:
activemq.broker.url=tcp://localhost:61616
mq.username=admin
mq.password=snehal
Note: AE uses the plain password; ActiveMQ validates it against the encrypted value.
Step 8: Restart Services (Correct Order)
net stop AutomationEdge
net stop ActiveMQ
net start ActiveMQ
net start AutomationEdge
⚠ Ensure only one ActiveMQ instance is running on port 61616.
Verification – Broker Authentication
  • Open ActiveMQ Console:
  • Login using:
  • Verify AE logs show successful broker connection.
PART 2: Enable JMX with Authentication
Objective
  • Secure JMX monitoring access
  • Prevent unauthenticated access
  • Meet audit / VAPT requirements
Step 9: Enable JMX in ActiveMQ
File:
Ensure broker has:
<broker useJmx="true" ...>
Step 10: Configure JMX Access Roles
File:
<ACTIVEMQ_HOME>\conf\jmx.access
admin readwrite
monitor readonly
Step 11: Configure JMX Passwords
File:
<ACTIVEMQ_HOME>\conf\jmx.password
admin Jmx@123
monitor Monitor@123
⚠ Passwords are stored in clear text by JVM design.
Step 12: Secure JMX Password File (MANDATORY)
Run CMD as Administrator:
cd <ACTIVEMQ_HOME>\conf
icacls jmx.password /inheritance:r
icacls jmx.password /grant "%USERNAME%:R"
icacls jmx.password /grant "Administrators:R"
✔ Only owner and administrators have read access
✔ ActiveMQ will fail to start if permissions are weak (expected behavior)
Step 13: Configure JMX JVM Options
File:
<ACTIVEMQ_HOME>\bin\activemq.bat
Add:
set ACTIVEMQ_OPTS=%ACTIVEMQ_OPTS% ^
-Dcom.sun.management.jmxremote ^
-Dcom.sun.management.jmxremote.port=1234 ^
-Dcom.sun.management.jmxremote.rmi.port=1234 ^
-Djava.rmi.server.hostname=localhost ^
-Dcom.sun.management.jmxremote.authenticate=true ^
-Dcom.sun.management.jmxremote.ssl=false ^
-Dcom.sun.management.jmxremote.password.file="%ACTIVEMQ_CONF%\jmx.password" ^
-Dcom.sun.management.jmxremote.access.file="%ACTIVEMQ_CONF%\jmx.access"
Step 14: Restart ActiveMQ
net stop ActiveMQ
net start ActiveMQ
Verification – JMX Authentication
Using JConsole:
Connection URL:
service:jmx:rmi:///jndi/rmi://localhost:1234/jmxrmi
Credentials:
Username: admin Password: Jmx@123
✔ Successful connection
✔ Invalid credentials are rejected
