Automating Active Directory tasks using AutomationEdge
Active Directory Plugin Documentation
Active Directory
Active Directory plugin steps are for the purpose of automating Microsoft Windows Active Directory tasks.
Prerequisites:
  1. Process Studio 5.0.0 and above, AutomationEdge 5.0.0 onwards
  2. Privileges to access Active Directory Server.
  3. PowerShell version 5 and above.
  4. To run AD steps PowerShell setup with Active Directory Modules must be done.
  5. Please refer Appendix 2: PowerShell Setup- Active Directory  for updating PowerShell Version and Active Directory module installation.
Below is the documentation of AD Plugin steps.
Add to Group
This step is used to add existing Active Directory Account to an Active Directory Group.
Input Tab:
Step Name
Configuration:
Server Name
Provide the Hostname/Server Name/Fully Qualified Domain Name/IP address of machine where Active Directory is hosted. This field is mandatory.
Port
The port number for Active Directory should be provided. If port number is not provided, internally default port for Active Directory is used i.e. 389. Port should be an integer.
Username
Provide User Logon Name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) of an Active Directory account to authenticate. This field is mandatory.
User Logon Name and User Principal Name are depicted below.
Password:
Accept Value as variable/static
Leave checkbox unchecked to accept Password value from a field in the previous steps of the stream using a drop down list.
Else enable checkbox for Password field to appear as Text box.
Password
Password is entered using a widget. The widget handles both Text Var (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory.
If checkbox above is enabled Password field appears as Text Var and accepts static or variable values. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Button: Test Connection
Verifies whether the connection is available or not.
For the purpose of verification fields coming from previous steps are not allowed since field values can only be accessed when workflow is in running state. Static values and environment variables are allowed.
Input Tab:
Input Fields:
Object Type
Object  Type allowed values are only “ ’User’,  ‘Computer’, ’Group’
Note: Double quotes (") and back quote (`) are not to be provided.
Object Name
Provide Object name of an existing account in Active Directory to Add to Group, corresponding to the Object Type chosen above.
  1. For object type User in Active Directory you may specify User logon name (e.g. sbrown, scott.brown etc.), User Principal Name (e.g. sbrown@autoedge.com) or User Name (CN).
  2. For object type Computer you may specify Computer Name (CN).
  3. For object type Group you may specify Group Name (CN).
  4. You may specify Distinguished Name or Canonical Name for User, Computer or Group object types.
The data type is string. This field is mandatory.
Object Name must be unique in Active Directory.
Note: Object Name(CN) in Active Directory should not contain a slash(/ or \)
Group Name
Existing Active Directory Group Name in formats such as Group Name (CN) or Canonical name or Distinguished name to which we intend to add an existing Active Directory object.
Note: Group Name(CN) in Active Directory should not contain a slash(/ or \)
Output Tab:
Output Field:
Result
Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”.
Successful execution shows user has been added to AD group. This field is mandatory.
Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in
Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests.
Active Directory: Search Account plugin step provides the list of all Active Directory Users or Groups for the specified Object Type for the Path specified and with Property search criteria provided.
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password
Specify the password for the username above. Password field appears as Text box and accepts static values or variables.
The data type is string. The field is mandatory.
For the purpose of verification fields coming from previous steps are not allowed. Static values and environment variables are allowed.
Input Tab:
Input Fields:
Object Type
Hover over the field to see Allowed values are ‘User’, ‘Group’.  The data type is String. This field is mandatory.
Path
Provide the path of an Active Directory object for Advanced Search usually Distinguished name (DN) (e.g. OU=Temp, DC=autoedge, DC=com) or Canonical name (e.g. automationedge.com/Temp) of the object.
Tabular Fields:
Atleast one Property Name, Search Condition and respective Property Value must be selected in the table fields.
Property Name
Double click to select Property Names form the pop up window. The data type is String. This field is mandatory. This field is mandatory.
Search Condition
Select a Search Condition from the dropdown list. Following are the values in the list.
Starts with
Ends with
Is (exactly)
Is not
Present
Not Present
Property Value
Provide a desired property value.
Output Tab:
Output Field:
Name
Specify an output field to hold the result- Name upon successful plugin execution.
The default label value for this field is “Name”. This field is mandatory.
Distinguished Name
Specify an output field to hold the result-Distinguished Name on the successful plugin execution.
The default label value for this field is “DistinguishedName”. This field is mandatory.
Advance Search returns Name and Distinguished Name as output. In case you need to use the output of Advanced Search but additionally need User Logon Name then you need to use Get User Properties step after Advanced Search in the workflow to get the User Principal Name by providing DN as input.
(e.g. Suppose you want to know Does User Exist/ Is Account Locked for all the users returned in Advanced Search, you need User Principal Name to input  DoesUserExist/IsAccountLocked steps. Get User Properties step after Principal Name can fetch the User Principal Name).
Create Account
Active Directory: Create Account Plugin step is used to create a new Active Directory user.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Accept Values from fields
Password
Password is entered using a widget called SecuredComboVar. The widget handles both Text Var(static value or environment variable) and Combo(drop down containing values from previous steps). This field is mandatory.
If checkbox above is enabled Password field appears as Text Var and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Input Tab:
Input Fields:
First name
First name of the user account to be created. This field is mandatory.
Last name
Last name of the user account to be created. This field is mandatory.
Full name
Full name of the user account to be created. This field is mandatory.
User logon name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) for the new account to be created.
User Logon Name is mandatory.
User logon password
Provide a password for the user Account to be created.
Path
Provide path of Active Directory object (usually DN, For e.g. OU=Temp, DC=autoedge,DC=com) where the User Account is to be created. This field is mandatory.
The account is created if the password fails for any reason. If you provide a password, an attempt will be made to set that password however, this can fail due to password policy restrictions. The user account will still be created and you may use Reset Account Password to set the password on that account. In order to ensure that accounts remain secure, user accounts will never be enabled unless a valid password is set or Password Not Required is set in AD.
Output Tab:
Result
Successful execution shows user account has been created.
Result label value is mandatory.
Failure reasons could be plugin validation related or target system errors such as user does not exist, internet connection does not exist, invalid server configuration details (server has rejected the client credentials), empty fields and others. These errors can be seen in the logging tab of process studio. The error can be captured in error handling as discussed in Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests.
Create Group
Active Directory: Create Group Plugin step is used to create a new Active Directory Group.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Password is entered using a widget called SecuredComboVar. The widget handles both Text Var (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory.
For the purpose of verification fields coming from previous steps are not allowed as field values can only be accessed when workflow is in running state. Static values and environment variables are allowed.
Input Tab:
Input Fields:
Group name
Provide an AD Group Name. The Group name must be unique in the active directory domain. This field is mandatory.
Group Scope
Allowed values for Group scope are “ ‘0’, ’1’, ’2’ or ‘Domain local’, ’Global’, ’Universal’ ”. This field is mandatory.
Group Display Name
Provide a display name of the Group. This field is mandatory.
Group Category
Group category allowed values are only “ ‘0’,’1’ or ’Distribution’, ‘Security’”. This field is mandatory.
Path
Provide the path of Active Directory object where the Group is to be created - usually Distinguished Name (DN) (e.g. OU=Temp, DC=autoedge, DC=com) or Canonical Name (e.g. automationedge.com/Temp). This field is mandatory.
Output Tab:
Result
Successful execution shows user group has been created.
Delete Account
Active Directory: Delete Account step is deletes an Active Directory User Account.
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Password is entered using a widget. The widget handles both Text Var (static value or environment variable) and Combo(drop down containing values from previous steps). This field is mandatory.
Input Tab:
Input Fields:
User Logon Name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) that is to be deleted. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted.
The data type is String. User Logon Name is mandatory.
Note: User Name(CN) in Active Directory should not contain a slash(/ or \)
Output Tab:
Output Field:
Result
Successful execution shows user account has been deleted.
Delete Group
Active Directory: Delete Group plugin step deletes an existing Active Directory Group.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Password is entered using a widget. The widget handles both Text (static value or environment variable) and Combo (drop down containing values from previous steps). This field is mandatory.
If checkbox above is enabled Password field appears as Text box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Input Tab:
Input Fields:
Group Name
Specify the Group Name (CN)/Distinguished Name/Canonical Name in active directory to be deleted. This field is mandatory.
Canonical name\Distinguished Name may be provided in the group name field to avoid duplicate group name errors.
Output Tab:
Result
Output field to hold the result of the successful plugin execution. The default value of this field is “Result”. This field is mandatory.
Disable Account
Active Directory: Disable Account Plugin step disables a user or computer account.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
If checkbox above is enabled Password field appears as a Text box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Input Tab:
Input Fields:
Object Type
Object Name
Provide an existing Active Directory object name (user or computer name) which we intend to disable.
  3. You may specify Distinguished Name or Canonical Name for both User and Computer object type.
Does Group Exist
This plugin checks the current status of an existing Active Directory Group.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Group name
Provide Active Directory Group name (CN i.e. Common Name) or Canonical name or Distinguished name to check if it exists. This field is mandatory.
Output Tab:
Result
Successful execution shows whether group exists or does not exist.
Does User Exist
The step is used to check the status of an Active Directory user if it exists or does not exist.
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
User Logon Name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) to check if user exists. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted.
Output Tab:
Output Field:
Result
Successful execution shows user exists. Result label value is mandatory.
Enable Account
Active Directory: Enable Account step is used to enable a disabled user or computer account.
Configuration:
Field Nameve
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Object Type
Object Type allowed values are only ‘User’, ‘Computer’.
Note: Double quotes (") or back quote (`) are not to be provided.
Object Name
Specify the name of an existing Active Directory object to be enabled, corresponding to the Object Type chosen above.
  3. You may specify Distinguished Name or Canonical Name for User, Computer or Group object types.
Get Computers
Active Directory: Get Computers plugin step provides the list of all active directory computers on a specified path for the hierarchical scope specified.
This is a row generating step and hence has to be the first step in a workflow.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password
Input Tab:
Input Fields:
Path
Provide path of Active Directory usually Distinguished Name (DN) (e.g. OU=Temp, DC=autoedge, DC=com or) or Canonical Name (e.g. e.g. automationedge.com/Temp) for which we want to get all the Computers.
The Data type is String. This field is mandatory.
Search Scope
Mouse hover on this element to see the allowed values ‘Base’, ‘OneLevel’, ‘SubTree’, OR ‘0’, ‘1’, ‘2’.
Specifies the scope of an Active Directory search. The acceptable values for this parameter are as shown in the table below:
Level
Base or 0
Base or 0 searches only the current path or object.
OneLevel  or 1
OneLevel or 1 searches the immediate children of that path or object.
SubTree or 2
Subtree or 2 searches the current path or object and all children of that path or object.
Output Tab:
Computers
Specify an output field to hold the Computer Name on the successful plugin execution. The default value for this field is “Computers”.
Distinguished Name
Specify an output field to hold the Distinguished Name of a computer on the successful plugin execution. The default value for this field is “DistinguishedName”.
Get Groups
Active Directory: Get Groups plugin step provides the list of all active directory groups on a specified path.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password
Input Tab:
Input Fields:
Path
Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Groups.
  1. Canonical Name can be viewed under Properties (while Advanced Featured are enabled in View menu) under Object
  2. Distinguished Name can be viewed under Properties (while Advanced Features are enabled in View menu) under Attribute Editor.
Path data type is String. Path is mandatory.
Note: Double quotes (") and back quote (`) are not required as part of input.
Search Scope
Level
Base or 0
OneLevel  or 1
OneLevel or 1 searches the immediate children of that path or object and excludes the base object itself.
SubTree or 2
Search Scope data type is String. It is mandatory.
Note: Double quotes (") and back quote (`) are not required as input.
Output Tab:
Groups
Specify an output field to hold the result of the successful plugin execution. Default label value for this field is “Groups”.
Distinguished Name
Specify a field name to store the Distinguished Names of the Groups retrieved. The default value is “Distinguished Name”.
Errors can be captured using error handling as discussed in Appendix 1: Error Handling in IT Plugins to make the error message visible on AutomationEdge Requests.
Get Group Properties
Active Directory: Get Group Properties plugin step gets the properties of an Active Directory Group.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Group Name
Specify an Active Directory Group Name (CN)\Canonical Name\ Distinguished Name to get the Group properties.
Canonical name\Distinguished Name may be provided to the group name field to avoid duplicate group name errors.
Output Tab:
Output Fields Tabular:
Property Name
Double click to get a list of Group property names. At least one property name should be selected.
Output Field
Specify a field name to store the retrieved property values of the corresponding property names.
Get Organizational Units
Active Directory: Get Organizational Units plugin step provides the list of all active organizational units for a specified path.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password
Input Tab:
Input Fields:
Path
Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Organizational Units.
  1. Canonical Name can be viewed under Properties (while Advanced Features are enabled in View menu) under Object in AD.
  2. Distinguished can be viewed under Properties (while Advanced Features are enabled in View menu) under Attribute Editor in AD.
Search Scope
Level
Base or 0
OneLevel  or 1
SubTree or 2
Output Tab:
OU Name
Specify a field name to store the OU names retrieved. The default value is “OU Name”
Distinguished Name
Specify a field name to store the Distinguished Names of the OU names retrieved. The default value is “Distinguished Name”
Get Last Logon Timestamp
Active Directory: Get Last Logon Timestamp plugin step gets the last logon timestamp of an Active Directory user or computer.
Configuration:
Step Name
Configuration:
Server Name
Provide the Hostname/Server Name/Fully Qualified Domain Name/IP address of the machine where Active Directory is hosted. This field is mandatory.
Port
Username
Password:
Password
Input Tab:
Input Fields:
Object Type
Specify Object Type - allowed values are only “’User’ and ‘Computer’”. The data type is String. This field is mandatory.
Object Name
Provide Object name of an existing account in Active Directory; that you wish to Remove from Group; corresponding to the Object Type chosen above. For object type User in Active Directory you may specify User logon name (e.g. sbrown, scott.brown etc.), User Principal Name (e.g. sbrown@autoedge.com) or User Name (CN). For object type Computer you may specify Computer Name (CN). For object type Group you may specify Group Name (CN). You may specify Distinguished Name or Canonical Name for User, Computer or Group object types.
Output Tab:
Last LogonTimestamp (UTC)
Output field to hold the result of the successful plugin execution. Default value for this field is “LastLogonTimestamp”. This field is mandatory.
Get Users
Active Directory: Get Users step provides the list of all Active Directory users on the Path specifiedThis is a row generating step and hence has to be the first step in a workflow.
Configuration:
No
Step Name
Configuration:
Server Name
Port
Username
Password
Input Tab:
No
Input Fields:
Path
Specify an Active Directory Path (Canonical name or Distinguished Name of an object) for which we wish to get all Users.
Advanced Features must be enabled from View menu to fetch Canonical name or Distinguished Name from the Object Properties.
  1. Canonical Name can be viewed in Properties under Object in AD.
  2. Distinguished Name can be viewed in Properties under Attribute Editor tab in AD.
Search Scope
Level
Base or 0
OneLevel  or 1
SubTree or 2
Output Tab:
Users
Specify an output field to hold the result (User Logon Name/User Principal Name) upon successful plugin execution. The default value for this field is “Users”.
Get User Groups
Active Directory: Get User Groups step provides the list of all groups for a specified user. This is a row generating step and hence has to be the first step in a workflow.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password
Input Tab:
Input Fields:
User Logon Name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) for which you need all the assigned groups.
You may also provide the User Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to fetch assigned groups.
Output Tab:
User Groups
Output field to hold the result of the successful plugin execution. Default label value for this field is “User Groups”. Result label value is mandatory.
Distinguished Name
Get User Properties
Active Directory: Get User Properties step gets the properties of an Active Directory user.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
No
Input Fields:
User Logon Name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal name (e.g. sbrown@autoedge.com) of the user for which you wish to fetch User Properties.
You may also provide the User Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to fetch User Properties.
Output Tab:
No
Output Tabular Fields:
At least one Property Name and Respective Output field should be provided.
Property Name
On Click, property names associated with the user are retrieved in a list. Select one or more Property Names one by one.
Output Field
Specify an output fieldname to hold the value of the corresponding Property Name.
Is Account Disabled
Active Directory: Is Account Disabled plugin step checks whether the current status of an existing Active Directory account is disabled.
Configuration:
No
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
If checkbox above is enabled Password field appears as Text b box and accepts static values or variables. Else if checkbox above is disabled Password field appears as a drop down to select fields from previous steps.
Input Tab:
No
Input Fields:
Object Type
Object Type: Allowed values are ‘User’, ‘Computer’.
The data Type is String. This field is mandatory.
Object Name
Output Tab:
No
Result
Specify an output field to hold the result of the plugin execution. Default label value for this field is “Result”. Result label value is mandatory.
If Account is disabled the Result is true else false.
Is Account Locked
Active Directory: Is Account Locked plugin checks whether the current status of an existing Active Directory account is locked.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
No
Input Fields:
Object Type
Specify an Object Type. The allowed values are ‘User’, ‘Computer’.
Object Name
Output Tab:
No
Result
Output field to hold the result of the successful plugin execution. Default label value for this field is “Result”. Result label value is mandatory.
Move Account
Move Account Plugin step is moves a user from one organization (OU) to another organization in Active Directory.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
No
Input Fields:
Object Type
Specify the Object Type. Allowed values are ‘User’, ‘Computer’, ‘Group’.
Object Name
Destination Path
Give the object path (usually OU DN) to which you want to move the active directory account
Specify the Object Destination Path as Distinguished Name Path (usually OU DN - e.g. OU=Temp, DC=autoedge, DC=com) or Canonical Name Path where the user is to be moved (e.g. automationedge.com/Temp).
Output Tab:
No
Output Field:
Result
Successful execution shows user account has been moved.
Get Password Expiration Days Left
Active Directory: Password Expiration Days Left plugin step searches a given Object (User or Computer) and gets password expiration days left.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Object Type
Specify Object Type - allowed values are “’User’ and ‘Computer’”. The data type is String. This field is mandatory.
Object Name
Output Tab:
Output field to hold the result of the successful plugin execution. Default label value for this field is “PasswordExpirationDaysLeft”. Result label value is mandatory.
Remove from Group
This plugin is used to remove an existing Active Directory account from an existing Active Directory group.
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Object Type
Object Name
Group Name
Existing Active Directory Group Name in formats such as Group Name (CN) or Canonical name or Distinguished name from which we intend to remove an existing Active Directory object. This field is mandatory.
Output Tab:
Output Field:
Result
Successful execution shows Account has been removed from Group.
Rename Account
Active Directory: Rename Account plugin step is renames an Active Directory Account.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
Object Type
Object Type allowed values are only “’User’, ‘Computer’, ‘Group’”. The data type is String. This field is mandatory.
Object Name
Specify an existing Active Directory object name to be renamed. For object type User in Active Directory you may specify User logon name (e.g. sbrown, scott.brown etc.), User Principal Name (e.g. sbrown@autoedge.com) or User Name (CN). For object type Computer you may specify Computer Name (CN). For object type Group you may specify Group Name (CN). You may specify Distinguished Name or Canonical Name for all User, Computer or Group object types.
New Name
Specify a new Name (CN) for the object to be renamed.
This field is a String. The field is mandatory.
The step is used to reset password of an existing AD user.
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
User logon name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name of an existing Active Directory user account (e.g. sbrown@autoedge.com) to reset password. You may also provide the Name (CN)/Distinguished Name/Canonical Name of an Active Directory user account to be deleted.
New Password
New password which we intend to set for the above User logon name. This field is mandatory.
Output Tab:
Output Field:
Result
Successful execution shows user password has been reset.
Set Password Properties
Active Directory: Set Password Properties plugin step sets password properties for an existing user account in Active Directory.
Configuration:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
User Login Name
User Must Change Password At Next Logon
Give the appropriate property value. Allowed values are ‘0’, ’1’ or ‘true’, ‘false’.
User Cannot Change Password
Password Never Expires
Unlock Account
The step is used to unlock AD user account which is locked (i.e. user account gets locked when we enter wrong credentials multiple times).
Input Tab:
Step Name
Configuration:
Server Name
Port
Username
Password:
Password
Input Tab:
Input Fields:
User logon name
Provide User logon name (e.g. sbrown, scott.brown etc.) or User Principal Name (e.g. sbrown@autoedge.com) of an existing Active Directory account to unlock account.
You may also specify Distinguished Name or Canonical of the User Account.
The data type is string. User Logon Name is mandatory.
Output Tab:
Output Field:
Result
Successful execution shows user account has been unlocked.
Known Issues:
These known errors are for all AD plugins
  1. If an invalid environment variable is provided as input to the plugin, then plugin validates it and throws error as “Failed to get <respective field name>”. But when the same workflow is executed through AutomationEdge, error thrown is not identical to the error thrown by process studio.
  2. When more than one consecutive space character is provided between to non-space characters and submitted as input to the plugin, then plugin receives input as two non-space characters with only one space character between them, instead of original multiple consecutive spaces.
    Reference Link: https://bugs.java.com/view_bug.do?bug_id=7028657
      Links to better reach
            Bot Store
             EPD
