Missing HTTP Headers – Implementation
Implementation Approach
To enhance application security, the following HTTP headers should be configured in the application.
Where to Add
File Location:
<AE_Application>/aeengine/WEB-INF/spring/security/spring-security.xml
Configuration
Add the following under the <headers> section:
<headers>
<cross-origin-embedder-policy policy="require-corp" />
<cross-origin-resource-policy policy="same-origin" />
<cross-origin-opener-policy policy="same-origin" />
<permissions-policy policy="geolocation=(self 'https://ae.com')" />
</headers>
Header Details
  • Cross-Origin-Embedder-Policy (COEP) → require-corp
    Controls embedding of cross-origin resources
  • Cross-Origin-Resource-Policy (CORP) → same-origin
    Restricts resource sharing to same origin
  • Cross-Origin-Opener-Policy (COOP) → same-origin
    Protects against cross-origin attacks (e.g., tab isolation)
  • Permissions-Policy → geolocation=(self 'https://ae.com')
    Controls browser feature access (e.g., geolocation)
    You need to configure the permissions-policy header to control which domains are allowed to access browser geolocation.
    In the line:
    • geolocation → controls access to location (GPS)
    • self → allows your own application domain
    • 'https://ae.com' → allows that specific external domain
    ✅ What you actually need to add
    👉 Replace 'https://ae.com' with the actual trusted domain (if any), or remove it.
    Best options:
    1. If geolocation is NOT required (recommended for VAPT):
    <permissions-policy policy="geolocation=()" />
    2. If only your application needs it:
    <permissions-policy policy="geolocation=(self)" />
    3. If external domain is required:
    <permissions-policy policy="geolocation=(self 'https://your-domain.com')" />
    ⚠️ Key Point
    • Do not keep ae.com unless it is actually used
    • Always allow only required domains (principle of least privilege)
Customization
  • The policy values should be updated based on client requirements and allowed domains
